Author Topic: How to get realtime.txt from IP/WIFI weather station  (Read 1033 times)
Offline pimohdaimaoh
  • "Be aware to our nature"
    • PIMOHWEATHER
« on: February 24, 2017, 08:47:54 PM »
Hello,
I need your help regarding my upcoming weather station, Im planning to purchase an IP/WIFI kind of weather stations that links its data through WIFI/IP. My question is how can I link its realtime.txt to this site http://pimohweather.webutu.com/wxindex.php if I have no idea where to get its realtime.txt, I only know that cumulus software only supports a wire linked consoles but not to a wireles consoles like WIFI/IP consoles. Thank You for the responses.
« Last Edit: February 25, 2017, 01:17:45 AM by pimohdaimaoh »
Offline waiukuweather
Re: How to get realtime.txt from IP/WIFI weather station
« Reply #1 on: February 24, 2017, 09:27:15 PM »
Hi
the weather display software can be set to work directly with the WIFI station (version with the console is easiest)
and be set to create the clientraw.txt file which that web site script can be set to use
just as an idea/solution
    • PIMOHWEATHER
« Reply #2 on: February 24, 2017, 10:08:58 PM »
Oh . . thanks for the idea I will try it once I get my weather station
