make sure the USB data logger is not set to USBexpress mode
i.e it needs to be in virtual serial port mode (i.e so that a com port number to use shows in device managers, ports)
Davis have a utility program to change the mode
(in weather link you then set to use serial mode instead of USB mode and set the com port number that windows allocates)
