Author Topic: Got 1-Wire, tell me about it...  (Read 5126 times)
Offline smasraum
« on: April 09, 2009, 02:38:51 PM »
So, I'm curious about folks' 1-Wire setups.  I've done lots of searches here and on the Internet and found very, very little info about 1-Wire stuff.  Well, let me amend that.  I've found lots of info about the technical specs of 1-Wire and the protocols and such.  I've found a few folks using the $100 AAG 1-Wire Weather station too.  I'm more curious about folks that have setup 1-Wire stuff piece-meal/DIY.  Apparently Dallas Semi used to have forums, but they're gone and only accessible to people who have logins from before they were taken down.
So, if you have one of the commercial 1-Wire WS (AAG or the other one, can't remember the brand) or if you're using a bunch of 1-Wire sensors/hardware with a PC as a weather station, tell me about your system.  What's worked, what's not worked if you bought kit stuff like from hobby boards or if you bought chips and made your own or if you've sourced stuff from other vendors (Datanab seems to have a slew of temp senders).
I'm trying to educate myself as much as possible before I start buying gear, but most of the info seems to either be very low level stuff about the chips or theoretical stuff about what could be done with the hardware.  I'm surprised there's not more practical info from folks that are using it.  Info about what's worked and what didn't work, what software folks are using and what they're using it for.
Offline Weather Display
Re: Got 1-Wire, tell me about it...
« Reply #1 on: April 09, 2009, 02:41:02 PM »
try the WD forum, lots of info/threads there
Brian
info@weather-display.com
Offline smasraum
« Reply #2 on: April 09, 2009, 02:50:47 PM »
Thanks, I'd not stumbled across that forum previously.
Offline wxtech
    • Lexington, Ga. Weather
« Reply #3 on: April 09, 2009, 03:00:33 PM »
I was intrigued by 1-wire.  Got it, set it up, made it work, gave it away.
Go here for all the info you'll ever need:  www.weathertoys.net or buy the book "Weather Toys" by Tim Bitson.  A 1-wire forum: http://www.weathertoys.net/phpBB2/index.php
The site and forum is also linked to Hobby Boards which is a supplier of all the bits and pieces you'll ever need.
I tried using Java to interface, preferred to use the Basic Stamp 2 for interfacing to the Maxim I2C devices.
It's a good system.  I still use the parts, just not as a 1-wire system.
One quirk that I ran into was searching the 1-wire bus to get the serial number of the devices on the bus.  Each device has it's own unique serial number.  PM me for how I made that work.
Offline smasraum
« Reply #4 on: April 09, 2009, 05:35:21 PM »
Thanks for the responses.  I'd seen the "weather toys" forums, and should have realized since the book is about 1-wire that the forums would be, but it didn't click.  I just knew there had to be some forums with more info, now I have 2.  Thanks again!
Offline smasraum
« Reply #5 on: April 10, 2009, 03:33:02 PM »
I found some links to a few interesting pages.
So here's some of what I've seen.
Good info here.
http://pond1.gladstonefamily.net:8080/sensors.html
http://pond1.gladstonefamily.net:8080/surge-protection.html
I really liked this page.  Lots of pictures and info.
http://www.tkup.net/data/info/
And this site has some good info
http://www.geocities.com/meteo19671967/
But it's a bit hard to follow the orange box full of links at the top.
Offline smasraum
« Reply #6 on: April 11, 2009, 12:02:10 AM »
I picked up "Weather Toys" tonight from the local Barnes and Noble.  I've got some reading to do.
« Reply #7 on: April 14, 2009, 11:10:09 AM »
Search for articles by "Dan Awtrey"  He's with Dalls Semi.  Lots of good stuff from him.
Offline smasraum
« Reply #8 on: April 14, 2009, 11:32:43 AM »
Thanks, will do.
« Reply #9 on: April 14, 2009, 11:54:38 AM »
Some of his articles are here:  http://1wire.org/  Along with lots of other  good stuff.  One wire is pretty neat and easy to use.
Offline smasraum
« Reply #10 on: April 14, 2009, 02:06:35 PM »
Yes, based on my reading, 1-Wire is really cool.  Simplicity and flexibility limited by nearly nothing but your imagination.
I've actually got some ideas for having the system touch my HVAC controls as well.
« Reply #11 on: April 14, 2009, 02:17:19 PM »
Here's a cooll 1-wire project:  http://scanwidget.livejournal.com/36187.html
Offline sam2004gp
  • Mount Crawford, Virginia
  • Weeeeeeeee!!!!
    • Mount Crawford Weather, VA
« Reply #12 on: April 14, 2009, 05:48:06 PM »
Wow that is neat,  That guy has some skills.  I wish my kodak picture frame had some wifi or ethernet, then I could do the same by storing a picture from VWS.
« Last Edit: April 14, 2009, 05:49:42 PM by sam2004gp »
Offline smasraum
« Reply #13 on: April 14, 2009, 10:16:37 PM »
Yeah, very cool.  Check out some of his other work.  He's a bit more advanced than I am, sheesh!
« Reply #14 on: April 15, 2009, 09:19:05 AM »
You can buy a WiFI digital pic frame for well under a hundred bucks now.  Hmmm... another weather toy to buy.  The CFO ought to be real impressed.  Not.
ANd yeah, that guy's done some neat stuff.
Offline Garth Bock
  • Table Rock Lake Weather
« Reply #15 on: April 22, 2009, 05:27:26 PM »
The picture frame is a cool idea. He said he is using an RSS feed through a custom script. I would like to just stream my graphs from the weather computer. Hmmm something to think about.............
Offline Garth Bock
« Reply #16 on: April 27, 2009, 04:22:04 PM »
Has anyone tried to do this with a wifi picture frame ? Sounds really interesting.
