Author Topic: Vantage Pro 2 low rain readings  (Read 5273 times)
Offline desrae20
« on: July 12, 2016, 04:10:22 AM »
 I have been monitoring the rain collection on my new Vantage Pro 2 for nearly 2 months, and believe compared to a co located manual gauge and other Australian BOM reading in the area it is reading about 20% lower.
Is there any means of manual adjusting the tipper mechanism to counter this low reading.
Des
Offline George Richardson
    • Smith Mountain Lake Weather
Re: Vantage Pro 2 low rain readings
« Reply #1 on: July 12, 2016, 07:20:11 AM »
Des,
All Davis sensor values can be calibrated, either in the console or, as is the case with the rain buckets, at the sensor. The adjusting screw for the rain bucket is 6% per revolution. However, speaking from bad experience, I would urge you to not adjust more than 1 revolution, allow several rain sessions to calculate the new offset and adjust again. If you say that 20% should be 3 1/3 revolutions, I'm afraid you will be way off (at least I was).
Good Luck,
George
Offline desrae20
« Reply #2 on: July 12, 2016, 07:41:26 AM »
Thanks for your reply, but where is this adjustment screw, I have found no reference in manual or am I only have a "man" look ?
Des
Offline moehoward4
  • Jack in SE MA.
« Reply #3 on: July 12, 2016, 08:17:46 AM »
Take the rain bucket off the base....at each end of the tipping bucket, mounted in the base are TWO adjustment screws(one each end), use a 3/16" wrench to adjust....there is a small diagram molded into the base giving you some help(+/-, %). Like George said, DO NOT get carried away with massive adjustments......
3 Davis set-ups...which one ya wanna talk about? And I got ALL my manuals....
Offline ericfynne
« Reply #4 on: July 12, 2016, 08:19:31 AM »
http://www.davisnet.com/product_documents/weather/manuals/07395-275_IM_07852.pdf
The screws are clearly shown on the diagram, and adjustment is described on pages 6 and 7.
Eric
Offline moehoward4
  • Jack in SE MA.
« Reply #5 on: July 12, 2016, 08:20:49 AM »
One more thing....EQUAL amount of turns each screw !!!!
« Reply #6 on: July 12, 2016, 08:50:35 AM »
My previous advice (consistent with what has been given here basically) is here: http://www.wxforum.net/index.php?topic=27966.msg270283#msg270283 The only thing that I would add is to calibrate with a known volume of water under controlled conditions. If you look at "rain gauge calibrators" they have a water reservoir that is fed through precision orifices to deliver the water under a constant, controlled rate.
This might be helpful as well: http://www.weather-watch.com/smf/index.php?topic=46062.msg374384#msg374384
I have not attempted to calibrate my current VP2 rain gauge, although I tried on an earlier Davis rain collector, with mixed results. I mounted a wind measurement set close to my lSS and found that there is undercount due to a rain shadow from the SE. Also, I think that the tapered cone aerodynamics may be contributing to a lift when wind is present, also lowering rain count.
I calibrated my NovaLynx 8" gauge using home-brew equipment consisting of a adapted PVC reducer and gas-jet orifice. I used the same 1g resolution scale that I use for CoCoRaHS snow SWE measurements to determine the water volume. This was an all-day project and I made several passes even after settling out on the final value to determine repeatability.
I would make comparisons between gauges only when there is fairly gentle to moderate rain and no wind.
Greg
Offline desrae20
« Reply #7 on: July 12, 2016, 09:58:23 PM »
Thanks Greg, George & Eric,
I have removed the collector cone and I can see the adjustments you are referring to.
In the manual 'Integrated Sensor Suite" that come with the unit there is no mention of the adjustment screws, but in the Rain Collector II that you linked me to it is quite clear.
I will heed your advice and adjust a little at a time.
Thanks again.
Regards,
Des
Offline desrae20
« Reply #8 on: July 12, 2016, 10:57:15 PM »
Hi again,
I did a rough test, using a syringe, and now find that each buckets takes about 5ml of water to tip, and then using formula h(cm)=v/ 3.14x("r"squared) gives a rough figure of .23mm per tip. (.023(cm)=5/(3.14x8.25x8.25)) Refer "The Weather Observer's Handbook" pg 306.  r=8.25cm is figure for Davis Vantage Pro funnel hole radius.
If this is right I still need some adjustments, but will wait for the real stuff to fall first.
All interesting
Thanks again,
Regards,
Des
« Reply #9 on: July 13, 2016, 01:34:25 AM »
Hi again,
All interesting
Thanks again,
Regards,
Des
I have no idea what you just said, but the correct amount per tip for a VP2 is 544ml.
Offline desrae20
« Reply #10 on: July 13, 2016, 01:48:23 AM »
I don't think so as 500ml is about 2 cups of water. ?
Des
« Reply #11 on: July 13, 2016, 02:42:47 AM »
Des
Oops! Forgot my decimal point, 5.44ml. :oops:
Offline desrae20
« Reply #12 on: July 13, 2016, 03:55:56 AM »
No worries, I thought that may be the case.
So my experiment that resulted in approx 5ml of water per bucket is not far out, and confirmed via that formula.
Thanks again for your help and interest.
Des
Offline Mattk
« Reply #13 on: July 15, 2016, 09:42:50 PM »
So is this setup as an imperial or metric rain collector? Reference to BOM and being AU one would suspect it is a metric collector? Hence the 5.44ml would not be correct?
« Last Edit: July 15, 2016, 09:45:32 PM by Mattk »
« Reply #14 on: July 15, 2016, 09:56:36 PM »
5.44 ml equates to 0.01 inch of rain.
Offline Mattk
« Reply #15 on: July 15, 2016, 10:06:49 PM »
Yes but for a Metric 0.2mm tipper setup the amount will be 4.26mm per tip. Australia is a metric country, rainfall is measured in mm's, hence the AU Davis version will be most likely be metric
« Reply #16 on: July 15, 2016, 10:54:32 PM »
I figured smart folks like yourselves would get the conversion.
Offline desrae20
« Reply #17 on: July 17, 2016, 08:42:36 AM »
Yes my rain gauge is set up for metric and the formula I referred to earlier confirms that the Davis gauge, to be exact, should tip with 4.26ml of water or .2mm of rain if the readings are to be accurate.
Thanks all for your interest I have appreciate the discussion.
Regards
Offline Mattk
« Reply #18 on: July 18, 2016, 03:33:56 AM »
20% low doesn't surprise me, that's about par for the course.
Offline desrae20
« Reply #19 on: July 27, 2016, 07:11:21 AM »
A follow up, I consider my rain gauge is now adjusted as close as I will get it and it eventually took 3.25 turn of the adjustment screws to complete this.
I emailed Davis re no mention in manuals supplied with the unit relating to the adjustment screws, and they replied that they would pass it on but they did not expect it to need adjusting as it was set in the factory.
Let it rain, and it has, as here in South Australia we have already had more rain than we normally have in a full year.
Regards and thanks for your help,
Des
Offline Mattk
« Reply #20 on: July 27, 2016, 07:20:53 PM »
Yes I have seen screw adjustment of 5 turns and by then the screw is just about out of the thread. Davis appear to have a fixed screw height setting depending on the model but did also hear there is some specific angle the tipping bucket is set to. In reality the only way check/validate is to do a calibration then adjust. One thing for sure is there is not a linear change between the number of turns and % change, must be changed gradually, re-calibrating each time.
PS Maybe Aussie rain is lighter than American rain  :grin:
« Last Edit: July 27, 2016, 07:22:43 PM by Mattk »
Offline WheatonRon
    • WUnderground
« Reply #21 on: October 09, 2016, 01:32:26 PM »
Des
This post is now a couple of months old. Curious. Do you think you fixed the calibration of your rain gauge? :-)
Offline desrae20
« Reply #22 on: October 09, 2016, 08:55:18 PM »
Yes I believe it is now adjusted, the main issue was knowing what to adjust as the manual supplied did not detail this, and thanks for the help from others,
In Sept South Australia has had it highest daily rainfall on record, over 100mm.
Regards,
Des
Offline WheatonRon
    • WUnderground
« Reply #23 on: October 09, 2016, 09:00:17 PM »
Regards,
Des
That's a lot of rain! The reason I was askng about adjusting the VP2s is I have two of them and am disappointed in their rainfall accuracy so I need to calibrate. Glad you were successful, hope I will be too!
Offline desrae20
« Reply #24 on: October 09, 2016, 09:18:25 PM »
Its a slow process, particularly if its not raining.
I have a manual  gauge mounted along side of the Davis and have been comparing and adjusting for sometime, trying to do a little at a time, fortunately winter has been a lot wetter than normal and it has given me the opportunity to compare and adjust.
Good Luck,
Des
