At night, I have stations on the water that contribute to the average of the analysis... They stay warmer, or cooler depending on the time of year. I also have stations inland, where the thermometers are very close to mine in daily highs. In the daytime, I run usually 1 F warmer than the average. One station in a Forest to my north typically runs too warm. The forestry service maintains it I believe. It also drops way off at night.
The acurite tower thermometers IMO are very accurate when they are shielded properly from the sun. If you just stick it out in a tree or on the side of a building, it will run high.
The 5 n 1 is on the roof now, but it is high enough over the roof to not be affected by it, and how I know this is the temperature sensor acts the same way it did before I moved it! No difference, still 3 - 5 typically high by day, and up to 8 F high I have seen the other day when the sun was in and out. Everything is stable and level. The wind speed is much more constant and steady on the roof for me, since this is as far from trees as possible, and wide open for rainfall, so this is the optimum location for the install.
