Author Topic: Ambient Weather WS-900-IP (Wireless) Hygrometer Error/Failure  (Read 461 times)
Offline JayTees
  • https://www.wunderground.com/personal-weather-station/dashboard?ID=KMOJACKS28
    • My Weather Station
Good Morning,
Main Unit - rooftop mounted
Temp/Pressure/Hygrometer (WH32E) - hung on north facing wall, under the eaves
In place January 31, 2018
I'm having an intermittent error with the outside Temp/Pressure/Hygrometer Sensor. Periodically the hygrometer will drop to absurdly low readings, i.e., in Southeast Missouri this morning the humidity IS 99%. My sensor was showing 3%! It will have drop outs periodically, starting April 22 (see attached image).
Any ideas about troubleshooting, or is this just, 'get a new one'? Just looked and it looks like my readings have jumped back up to expected.  :roll:
P.S. Just wanted to note that this is a reading found on on-line consoles as well as looking at the outdoor unit itself.
« Last Edit: June 16, 2018, 09:21:32 AM by JayTees »
When in danger, or in doubt,
Run in circles, scream and shout!
Offline JayTees
Re: Ambient Weather WS-900-IP (Wireless) Hygrometer Error/Failure
« Reply #1 on: June 24, 2018, 10:26:20 AM »
In case someone else has this same problem, I emailed Ambient Weather about this problem and they are going to issue an RMA for my sensor. Hope that solves that problem.
Now, if the connection to Wunderground would lose its occasional flakiness . . .
« Last Edit: June 25, 2018, 06:35:36 PM by JayTees »
