I would like an auto adjusting clock! These are all changes I would like on the display.1) Show the "Feels Like" Temperature (THW Index) - The current console displays Wind Chill or Heat Index, displaying the THW Index would eliminate the need to keep switching between the two.
2) Show the Dew Point as a separate value - The current console makes you choose between Dew Point, Heat Index and Wind Chill.
3) Show the 10 minute Wind Gust Speed in addition to the 10 minute Average Wind Speed. - Currently only the 10 minute Average Wind Speed can be shown at the bottom of the display. (Being able to graph the gust speeds would also be nice)
4) Update the wind-rose to show the Wind Direction as an arrow on the outside pointing in (technically the correct way) and have an "analog" display of the Wind Speed on the inside (1 dot for each MPH), with an additional point at the 10 minute Wind Gust Speed.
As far as the station as a whole:1) Heated Anemometer.
2) Infra-red Temperature Sensor, for pavement surface temperature sensing.
3) The ability to add temperature sensors on the wired version.
