Author Topic: Uploading?  (Read 1717 times)
Offline Phipps
Uploading?
« on: October 05, 2015, 09:03:31 PM »
Is there anyway to confirm Cumulus is uploading data?
Everything looks good from my end, but WU is saying my station is down. I don't see an errors and all my settings are correct.
Offline PaulMy
Re: Uploading?
« Reply #1 on: October 05, 2015, 10:31:53 PM »
You can tick Debug log in Configuration, and after a few WU scheduled uploads check the file to see if anything shows.
Offline Phipps
Re: Uploading?
« Reply #2 on: October 06, 2015, 06:31:05 AM »
Thank you. I will give that a try.
Offline Phipps
Re: Uploading?
« Reply #3 on: October 06, 2015, 08:10:15 AM »
I turned on debug in Configure. It logged for 5 minutes and then logging turned off. Not sure what I should be looking for, but in what was logged I didn't see anything about WU.
Offline Phipps
Re: Uploading?
« Reply #4 on: October 06, 2015, 08:28:00 AM »
Would Cumulous not upload the data if it detected missing data? My outside temp had been down and I reset everything this morning and the restarted Cumulous and now it's reporting again.
Offline mcrossley
    • Wilmslow Astro
Re: Uploading?
« Reply #5 on: October 06, 2015, 08:56:37 AM »
Correct, Cumulus doesn't do the uploads if any of the basic data is missing - in particular pressure and external temperature. IIRC you can over ride that behaviour with an ini file setting.
Offline Phipps
Re: Uploading?
« Reply #6 on: October 06, 2015, 03:11:09 PM »
Well, that explains a lot!! Thanks!!
