Not mine.
I have two stations, one "experimental". It's experimental in the sense that it's using custom software to send the data more frequently (1 minute) than the standard Acurite 15-minute-based method. Essentially it's the same data source, but with more frequent reporting. The data are obviously in-line with each other.
However, the 15-minute Acurite station has a tendency to "drop" for some reason and come back on its own. It might be the reporting frequency, or perhaps it's caused by a glitch at the AcuRite data center. I've no idea. All I can tell you is that my experimental station reports at 1-minute intervals and goes around the AcuRite data center, yet it stays on-line. It only drops if I take it down or the whole system crashes.
The only time I've heard of wunderground removing a station for problems is if the temperature is way out of line.
My humidity reading has been broken for months at a time due to the well-known AcuRite sensor problem, yet Wunderground didn't complain a bit.
It's not too particular about the barometer reading, either. I've sent absolute, MSL, and randomly calibrated and they don't seem to notice.
The only service I know of that actively drops like described is CWOP. Wunderground seems overly-tolerant of goofy data.
