Hello everyone. I installed a new weather station on 9/3/18, that is, I replaced the sensor suite because I was having various problems with it and it was 10 years old. Everything else is the same with my setup:
cabled sensor suite
Weather Envoy with data logger connected to modem and computer
Weatherlink IP that uploads data to Davis and WU
Weatherlink 6.0.3 software on my Windows 10 pc
The new weather station worked great for about 3 weeks. I was in and out of town for the months of September and October so I didn't have time to monitor it closely and I'm just now trying to figure out what happened.
After 3 weeks, there started to be missing data each day for a block of time between about 9a and 6p, and the size of the interval varied. Then, after a week of days with missing data, no data at all. Looking at the Browse window in WL, all I get now is barometric pressure and inside temp. I believe both of those sensors are on the Envoy (?) so it seems I'm not getting anything from the outside sensors. I checked all my cable connections, and I tried deleting the *.dat files from my weather database, but still no luck.
I also tried checking the continuity in the cable from the station to the Envoy and I can't verify that it's OK (I don't have 100% confidence in the tester) but it seems unlikely that the cable would spontaneously fail after 10 years with no problems.
Any other things I should try before replacing the cable? Thanks in advance!
