I mean the square logger pin out thing that connects the IP Ethernet to the logger itself. The thing with pins in. Sorry for lack of techy terms here.
I would have preferred that you remove the logger from the console, but ........
The wlk files don't have name dates in the future, like mentioned elsewhere, eg 2016. They all seem to be in order.
By "in between" I meant that I deleted all wlk files in between powering the logger down and powering it back up.
I asked for the "dates (f
ile dates - not the name) on those files" - but if you actually deleted
all of the .wlk files, then that's not an issue.
When you say "clear the logger" I am not sure how to do this.
One easy way is to use WeatherLink to "set the date and time on the console". Make a minor change, then change it right back. When you confirm that, you will be asked if you want to clear the data. Say yes.
Note that this operation will lose all of the historical data in the logger. But if you've tried everything else, that "should" fix your problem.
Please let us know.
