Author Topic: WL and screen saver  (Read 3566 times)
Offline lauraq
WL and screen saver
« on: May 28, 2007, 01:54:13 PM »
I'm using WL to download to CWOP and wunderground. I notice, however, that when WL is running, even minimized, my screen saver never comes on. This is a problem if I keep the computer running 24/7. Any suggestions?
Thanks!
Laura  :D
Offline racenet
    • NH Weather Data
Re: WL and screen saver
« Reply #1 on: May 28, 2007, 04:48:45 PM »
Set the monitor to power down within your power setting in the control panel. This is the method I use and set mine for 20 minutes. Or, and I don't mean to sound like a smart ass, press the monitor power button to the OFF position. Either way will work well.  :wink:
By the way, welcome to the forum!  8)
Bob
Offline lauraq
« Reply #2 on: May 28, 2007, 04:55:27 PM »
:)  Hi, Bob:
I've tried the setting in Control Panel to power down the monitor, but it doesn't seem to work. I'll give it another try and make sure everything is set right.
Yep, I figured the last resort was to manually turn off the monitor.
Thanks for the welcome!
Laura
Offline lauraq
« Reply #3 on: May 28, 2007, 05:01:31 PM »
:roll: Okay, so Bob was right. Set the monitor to turn off after 20 minutes and it works fine. Problem solved. Thanks for the advice, Bob!
Offline racenet
    • NH Weather Data
« Reply #4 on: May 28, 2007, 08:46:29 PM »
Laura,
Glad to hear that all is working as it should now. I know how you feel. It's the little things that drive you insane.  :wink:
Bob
Offline tweatherman1
    • http://webpages.charter.net/tweatherman67/index.html/
« Reply #5 on: May 30, 2007, 09:22:33 AM »
Laura,
What are your call signs on cwop and wunderground.
Welcome,
Tim
Offline lauraq
« Reply #6 on: June 12, 2007, 10:36:11 AM »
Hi, Tim:
On CWOP it's KI6AOK. Wunderground is KCASANMA10.
