This is today's message from CoCoRaHS
CLEAN UP TIME!
Is your rain gauge inner-cylinder starting to look a little grungy these days? It's that time of year! For most of us dirt will eventually build up on the bottom of your CoCoRaHS rain gauge inner-cylinder. In humid climates, algae growth can also be a bother.
If you want to keep your gauge clean and looking like new, put some warm water with a little gentle liquid hand soap in the tube and let it soak for a few minutes. Then twist a thin soft towel and spin it into the cylinder until it reaches the bottom. This will wipe out most of the dirt. It is not recommended to use a firm bottle brush to clean the gauge, nor is using your automatic dishwasher (This will gradually scuff and haze the inside of the gauge).
Another method is to take a newspaper, role it to make a tight cylinder, and then rotate the paper on the inside of the tube all the way to the bottom. It will usually clean out the dirt.
If you have other great solutions for keeping your gauge clean and looking like new, send them to: info@cocorahs.org with a subject line “Clean Gauge”.
