Author Topic: not picking up censer  (Read 877 times)
Offline okieman98
  • new and learning
« on: January 29, 2018, 08:42:40 PM »
removed old hub and installed the access. removed the lighting censer also when changing over but the new hub will not show it in the censer area of devices on my accurite it not scanning for it are not seeing it. i know its working because my monitor still shows it. any ideas to fix this. rebooted hub and computer and changed battery still not picking it up
PWS ID HEALDTON
Offline Glenn
Re: not picking up censer
« Reply #1 on: February 01, 2018, 08:12:36 AM »
Try another reboot with the Access. Let it sit for a minute or two unplugged and with the batteries removed.
Acurite 5 in 1 Pro+
Southern VT
Connecticut
Offline nincehelser
« Reply #2 on: February 01, 2018, 12:14:12 PM »
The $20 stand-alone lightning sensor is not compatible with either the SmartHUB or the Access.
I doubt the SmartHUB firmware will be updated again, but the Access may support it in the future.
Offline okieman98
  • new and learning
« Reply #3 on: February 01, 2018, 10:50:53 PM »
ok thinks thought i use to get the humidity and temp from it just not the lighting part on my acurite
PWS ID HEALDTON
