I just noticed that my Vue console and WL dew points don't always sync. The crossover to the higher integer on the console is occurring 0.7F too soon when compared to WL display. For instance, when the dew on WL says 52.7, the console reads 53, as it should. When the dew goes to 52.8, then the console jumps to 54, when it should remain 53. I even took the offset out for the 31 and the problem remained. Would some of you guys mind checking if your's do the same? I don't have my VP2 console to check if it's an issue there too.
Davis support was of no help, but I asked them to research it.
