Author Topic: WEATHER34 TEMPLATE with meteobridge options  (Read 89555 times)
Offline weather34
Re: WEATHER34 TEMPLATE with meteobridge options
« Reply #425 on: March 31, 2019, 02:58:26 AM »
thanks to Ken True
wu forecasts much improved and 60-70% reduction in code .  4 files related forecastwu.php , outlookwu.php and two css files (minor alignment for wu forecast)
as always  https://github.com/weather34/Meteobridge-Weather34-Template
ps the ability to track improvements via Github is really beneficial , I simply follow Ken and it gives the ability to track changes,improvements with an email notification..Github is the way forward for getting updates be it a small or significant update.
screenshot no real significant visual change but the underneath quite significant reduction in code..many thanks to Ken True.
Offline txweather.org
    • Texas Weather
« Reply #426 on: March 31, 2019, 05:42:21 AM »
Thanks for this awesome update!
« Reply #427 on: March 31, 2019, 04:14:55 PM »
Hi Brian,
Thanks for the kind words about my code simplification of your original WU/TWC scripts.  I try to make code that I can easily maintain in the future, so using a loop to run through the JSON of the forecasts makes for much smaller code and easy to change the presentation of each variable (so it applies to all the instances).
Best regards,
Ken
Offline prestwickwx
« Reply #428 on: April 01, 2019, 02:31:59 PM »
Brian,
Just noticed that the 40.svg icon (Heavy Rain) must be missing from the WU forecast.
Best Wishes,
Chuck
Offline weather34
« Reply #429 on: April 01, 2019, 03:07:35 PM »
thanks added 2 icons to repo 40.svg nt_40.svg
Offline prestwickwx
« Reply #430 on: April 01, 2019, 03:41:40 PM »
Got it, thanks!
Best wishes,
Chuck
Offline bthoven
    • Europa Cafe' Private Observatory
« Reply #431 on: April 02, 2019, 08:00:15 PM »
I installed the very early version long time ago for my weewx setup. How can I upgrade to the latest version without having to set up again.
Thank you very much for the beautiful dashboard.
Offline weather34
« Reply #432 on: April 03, 2019, 02:10:20 AM »
hello good morning
you will need to contact Ian Millard for anything reference weewx . I simply have no idea or any experience of weewx.
https://github.com/steepleian/WX-HWS
Offline weather34
« Reply #433 on: April 03, 2019, 02:11:57 AM »
good morning
new option added based on a idea suggested many thanks Derek .
screen below shot gives the drift of what it does..basically shows current forecast period in a single module
Offline xxvincixx
« Reply #434 on: April 07, 2019, 03:15:24 AM »
Hi everyone .. I recently bought the meteobridge nano sd and I'm using the local dashboard included ... Only I noticed that the design is different from the others .. Why? I would like to have what other users who use meteobridge have ... I enclose the 2 screens to let you see the differences ... 😁 😁
The first screen (round temperature icon) is mine, instead I'd like to have the dashboard like the second screen ..
« Last Edit: April 07, 2019, 06:19:12 AM by xxvincixx »
Offline prestwickwx
« Reply #435 on: April 07, 2019, 09:59:40 AM »
good morning
Brian,
This is a nice option!
Thanks to you, and Derek.
Chuck
Offline weather34
« Reply #436 on: April 07, 2019, 02:44:13 PM »
no problem chuck
think thats as much as I can do with the newer WU api and always good to have options.. needs a slight tweak on the colors for temperature but apart from that think ill just fix some other minor issues this week and then hand it all over ..let someone else focus on anything in the future..
as always chuck its good you follow the updates and your station and area always highlighs those minor annoyances I just dont see or forget to cross check ..i.e colors on the wu temperature and feels like
Offline gand
    • Lynghuzed
« Reply #437 on: April 09, 2019, 04:06:06 AM »
Hi
Just some cosmetic things.
With the latest WU Forecast update, You have "AM Clouds" and "PM Sun". Using the 24-hour clock the correct wording could be "Morning Clouds" and "Afternoon Sun"
Also in the Moon Phase module and the Moon Info module there are some AM/PM, even I'm using the 24-Hour clock.
Thanks for a great template.
Rgds
gand
https://lynghuzed.dk/
Offline weather34
« Reply #438 on: April 09, 2019, 04:25:46 AM »
Hi
Rgds
gand
good morning mr cosmetic :-)
the weather underground is like that in the API output apart from writing a load of what if ! or else ! statements not much we can do
you can see in the api output
"wxPhraseLong":["AM Clouds/PM Sun","Mostly Clear","Partly Cloudy","Mostly Cloudy","Cloudy","Partly Cloudy","Cloudy","Cloudy","Cloudy/Wind","Cloudy","Cloudy/Wind","Partly Cloudy/Wind"],"wxPhraseShort":["AM Clouds","M Clear","P Cloudy","M Cloudy","Cloudy","P Cloudy","Cloudy","Cloudy","Cloudy/Wind","Cloudy","Cloudy/Wind","P Cldy/Wind"]}]}
ive updated the repo the file livedata.php see if that helps ? let me know ..brian
Offline gand
    • Lynghuzed
« Reply #439 on: April 09, 2019, 04:33:52 AM »
Hi Brian
Thanks for the fast reply/fix.
Moon Info and Moon Phase are perfect now.
Rgds
Gand
Offline weather34
« Reply #440 on: April 09, 2019, 04:53:40 AM »
have a great day..brian
Offline weather34
« Reply #441 on: April 09, 2019, 01:01:40 PM »
a long overdue idea finally done barometer almanac (barometeralmanac.php )
and simplifying the basic days ahead awareness using weather underground API (forecast3wularge.php)
Offline prestwickwx
« Reply #442 on: April 09, 2019, 01:03:17 PM »
no problem chuck
We will certainly miss your tweaks and updates, but you have earned a well deserved break from WX templates!
Best wishes,
Chuck
    • Texas Weather
« Reply #443 on: April 09, 2019, 01:14:24 PM »
Thanks for your update!
Offline weather34
« Reply #444 on: April 09, 2019, 01:14:57 PM »
chuck 23rd april cant come quick enough not because of wx  templates just last minute thoughts of having prepared everything and that nervousness feeling inside the stomach.its like one hand on the pot of gold but you need two hands on it to own it ..brian
Offline weather34
« Reply #445 on: April 11, 2019, 04:51:41 AM »
nearing completion of all ideas ...
all almanac modules simple rework with relative indicators ...
Offline xxvincixx
« Reply #446 on: April 11, 2019, 11:36:32 AM »
Hi everyone, I have a meteobridge nano sd and besides the local dashboard I wanted (through the altervista site that I just created) to meet the weather34 dashboard on the site to share it on the net .... I followed the steps described on the site, so I have downloaded the zip file, unzipped on the desktop, then through filezilla I created a folder (pws) and transferred via ftp to altervista the files inside the folder created on the desktop ... the next step would be to identify my domain to enter the dashboard , I just don't know how to do it or I don't know how to do it anyway .. because if I try to click to enter my site it gives me nothing ... what am I wrong ??? could you help me ??? thank you so much
Offline prestwickwx
« Reply #447 on: April 11, 2019, 02:56:18 PM »
I don't have any specific knowledge concerning Altervista, but you should be able to login to your Dashboard at http://"Your_Altervista_Domain_Name"/pws/easyweathersetup.php.
Chuck
Offline xxvincixx
« Reply #448 on: April 11, 2019, 03:08:37 PM »
Don't work..  I don't understand what I'm wrong..
« Reply #449 on: April 11, 2019, 03:23:26 PM »
On altervista, you have to enable external HTTP requests in the control panel .. otherwise, the forecast won't work at all.
