Author Topic: WEATHER34 TEMPLATE with meteobridge options  (Read 89018 times)
Offline weather34
« on: February 21, 2017, 02:59:28 PM »
download via
https://github.com/lightmaster/Meteobridge-Weather34-Template
slimmed down version for weatherflow
https://github.com/weather34/Weather34-Weatherflow
a screenshot of last module weather34 worked on...
« Last Edit: May 24, 2019, 07:13:05 AM by weather34 »
Offline bchwdlks
Re: HOMEWEATHERSTATION TEMPLATE with meteobridge options
« Reply #1 on: February 23, 2017, 02:55:41 PM »
Firstly big thanks and acknowledgement to Wim AND Brian for the scripts and help.
Set up Meteobridge to use  HOMEWEATHERSTATION  in 3 easy steps
  • Go to the Meteobridge "services" tab
  • Add a new “HTTP Request” of the “Periodical” type
  • The 'template' is:“http://(Your HOMEWEATHERSTATION url)/mb.php?d=[DD]/[MM]/[YYYY]%20[hh]:[mm]:[ss]%20[th0temp-act]%20[th0hum-act]%20[th0dew-act]%20[wind0avgwind-act]%20[wind0wind-act]%20[wind0dir-act]%20[rain0rate-act]%20[rain0total-daysum]%20[thb0seapress-act]%20[wind0dir-act]%20[wind0wind-act=bft.0]%20m/s%20C%20hPa%20mm%20--%20[thb0seapress-val60:--]%20[rain0total-monthsum]%20[rain0total-yearsum]%20[rain0total-ydaysum]%20[thb0temp-act]%20[thb0hum-act]%20[wind0chill-act]%20[th0temp-val60:--]%20[th0temp-dmax]%20[th0temp-dmaxtime]%20[th0temp-dmin]%20[th0temp-dmintime]%20[wind0avgwind-dmax]%20[wind0avgwind-dmaxtime]%20[wind0wind-dmax]%20[wind0wind-dmaxtime]%20[thb0seapress-dmax]%20[thb0seapress-dmaxtime]%20[thb0seapress-dmin]%20[thb0seapress-dmintime]%20[mbsystem-swversion:--]%20[mbsystem-buildnum:--]%20[wind0wind-max10]%20--%20--%20[uv0index-act:--]%20--%20[sol0rad-act:--]%20[wind0dir-avg10:--]%20[rain0total-sum60]%20--%20[mbsystem-daynightflag:--]%20--%20[wind0dir-avg10:--]%20--%20m%20--%20[mbsystem-daylength:--]%20--%20--%20[uv0index-dmax:--]%20[th0hum-dmax]%20[th0hum-dmaxtime]%20[th0hum-dmin]%20[th0hum-dmintime]%20[th0dew-dmax]%20[th0dew-dmaxtime]%20[th0dew-dmin]%20[th0dew-dmintime]"
  • The SAVE button is at the Bottom of the ‘Services’ tab – it might not be visible on the screen and can be very easy to miss. I KNOW  :oops:
  • Click the TEST button and you will have a MBrealtimeupload.txt in your "HOMEWEATHERSTATION " directory.
Offline gateway2capecod
    • West Wareham, Ma Weather
« Reply #2 on: February 26, 2017, 12:12:27 PM »
hello....
trying out the template here using davis vantage vue and Meteobridge....
http://www.gateway2capecod.com/pws/index.php
...chris
Offline thomas
« Reply #3 on: February 26, 2017, 04:30:20 PM »
To clarify I will also need to put the two cron line requests into the Meteobridge that are mentioned in the other thread to get this to update.
Offline Torjan
    • regnskvett
« Reply #4 on: February 27, 2017, 05:29:57 AM »
Hi!
Tests this fine script. I use meteobridge pro and have set up using clientraw.txt file, which is part of metobridge pro. This seems to be working fine.
http://foreneset.no/pws/
Torjan
« Reply #5 on: February 27, 2017, 09:31:07 AM »
hello Torjan..
looks good.....How did you get your WEBCAM image in the dashboard down at the bottom in the UV section?
what file did you edit to do this?
Thanks...Chris
« Reply #6 on: February 27, 2017, 09:35:41 AM »
Hello Thomas......
this is screenshot of what I set in my Meteobridge for the 2 cron files ...
Offline Torjan
    • regnskvett
« Reply #7 on: February 28, 2017, 10:55:57 AM »
hello Torjan..
Thanks...Chris
Hi!
index file is what I have modified.
Think the best would be if it were made a standard for the use of webcam.
Torjan
Offline docbee
  • Moderator
    • smartbedded
« Reply #8 on: February 28, 2017, 05:57:46 PM »
Great work!
When you have defined the necessary upload patterns, I can encapsulate this into a weather network upload where user just have the give credentials and a target URL. This will make it users more easy to feed the service. Just let me know, when you have defined all the upload templates. Please also think about what should be uploaded, when data of a sensor is not there. I see that you don't make much use of default values (which handle such situations) in the templates so far.
Offline weather34
« Reply #9 on: March 01, 2017, 03:58:10 AM »
Good Morning
NO MORE CROBS JOBS EVERYTHING DONE IN EASYWEATHERSETUP.
Once again I have listened as the popularity has increased I have noticed the increase in server support required and the main obstacle for some
was understanding cron job configurations at server level so instead ignoring the concern came up with a standard script to eliminate cron jobs.
So tested over a two week period the template does not use any cron jobs for updating forecast or current conditions and getting your data for charts via WU
it is automatically retrieved every approx 15/30 minutes .
so forecast, current conditions update every 15 minutes
chart data is updated every 30 minutes .
now everything is basically setup via the easyweathersetup.php (easy setup screen), for the experienced you can still tweak and edit other files
for personal preferences other than that there is no requirement at all to ever edit the code.
if you have used previous versions of template you may want to cancel those cron jobs in your channel or external services as those files do not exist anymore.
two minor newer additions
1.removed Fire Risk until I can closely observe exactly how valid or useful it is in general i will add it an option in the near future , it has been replaced by a
simple Feels:Description
2.Extra conditions text has been added to the current icon description
see the demo at https://boutiquehotelitaly.com/devpws/
download at https://www.weather34.com/homeweatherstation/index.html
« Last Edit: March 01, 2017, 04:03:46 AM by weatherist34 »
Offline droiddk
« Reply #10 on: March 01, 2017, 11:58:54 AM »
Hi Brian
Also Meteobridge users?
Regards
Offline weather34
« Reply #11 on: March 01, 2017, 12:04:09 PM »
Hi Brian
Regards
hello
there is no change to how the 2 options of meteobridge is used with the template, cron jobs in the past versions were required for forecast, current,charts,earthquake data this caused a bit of a stumbling block for some so eliminates that issue . only thing to note so far since download released is check file permissions inside jsondata folder .
FOPEN is still required to be enabled at server level.
brian
Offline droiddk
« Reply #12 on: March 01, 2017, 12:05:03 PM »
Hi Brian
Regards
hello
brian
Ok, Thanks.
Regards
Offline thomas
« Reply #13 on: March 02, 2017, 10:09:32 AM »
I have installed the latest non-cron version but the but the weather underground data stays off line.
http://www.grr-cascade.com/DashboardV34E/
Offline Torjan
    • regnskvett
« Reply #14 on: March 02, 2017, 10:44:46 AM »
Hi!
Just so you know, here it seems fine with the new version without crone.
Torjan
Offline weather34
« Reply #15 on: March 02, 2017, 12:10:43 PM »
hello
you have something very very amiss somewhere http://www.grr-cascade.com/DashboardV34E/jsondata/wuweatherupdate.json
this file is is full of something to which I have no idea
i really don't know what is happening there i would suggest delete the file wuweatherupdate.json and let it create another and see what happens
its full of unrelated scripts calling cloud fare ,google  and many others here is just a couple of lines
 src="//ajax.googleapis.com/ajax/libs/jquery/2.1.1/jquery.min.js"></script>
      link type="text/css" rel="stylesheet" href="//cdnjs.cloudflare.com/ajax/libs/fancybox/2.1.5/jquery.fancybox.css" media="screen" />
      script src="//cdnjs.cloudflare.com/ajax/libs/fancybox/2.1.5/jquery.fancybox.pack.js"></script>
it is same for basic script for everyone and demo at http://boutiquehotelitaly.com/devpws/ only issue arises so far has been file permission for one person which was simple to rectify .
brian
« Reply #16 on: March 03, 2017, 03:01:04 PM »
hello....
I have the new NO CRON JOB Script running here.....http://www.gateway2capecod.com/pws/index.php
and I have the correct current time for my area showing, BUT THe Sunrise and sunset times seem to be off by about 2 hours.
Any Idea what is wrong and how to correct?
attached is my setting for time zone and latitude and longitude in my settings section.
Thanks...Chris
« Reply #17 on: March 03, 2017, 03:08:42 PM »
nevermind I figured it out.....
I was suppose to have  -5 for UTC OFFSET
and then was suppose to have  -70.9191020  for longitude
after make both these adjustments my time is now correct presently at 15:06pm for Friday afternoon, and sunset and sunrise times also are correct.
Another question...when we turn our clocks ahead 1 Hour next weekend for Daylight savings time, will I have to adjust my UTC OFFSET From the  current -5 to  -4? or just leave it alone and it will correct itself?
Thanks...chris
Offline weather34
« Reply #18 on: March 04, 2017, 02:33:03 AM »
Thanks...chris
good morning
sorry for the delay I was travelling last night , yes that is correct when the clocks go forward or back just adjust the easysetup , for us in Istanbul we no longer change times we are on the same time all year round since 2016 php timezones do not recognise the true time here I have to use Baghdad !!
have a nice weekend..brian
« Reply #19 on: March 04, 2017, 10:44:00 AM »
Thanks for that information Brian as I had thought about the time change as well.  I think the last time we had our time change I had PWS updates (i.e. new install) about the same time so used the UTZ minus our time time in the new settings file at that time.
All looking very nice,
www.komokaweather.com/pws
Offline weather34
« Reply #20 on: March 09, 2017, 06:12:15 AM »
Great work!
hello
my sincere apologies i didn't see this post it has just highlighted to me in an email.
I will reiterate i don't own or use a meteobridge product , i think I've highlighted before it is not possible to import one of those here in Turkey with a mass of paper work clearance etc..
I simply rely on user input to make this compatible with meteobridge , much of the usage is down to Wim and others . anything I do is just based on that feedback , my input is purely design based .
so enlighten me more on how we can make it better , easier etc . I'm all ears and always open to improvements,suggestions from anyone.
so sorry for the delay in replying ...brian
Offline thomas
« Reply #21 on: March 10, 2017, 07:06:50 PM »
Brian
I think what they are talking about is that meteobridge comes with set of weather networks built in like weather underground, cwop, windfinder etc.  Once setup you would pick Homeweatherstation and the data would go to where you choose.
Offline prestwickwx
« Reply #22 on: March 12, 2017, 03:34:13 PM »
This is an excellent template. Many thanks to Wim AND Brian for their work. I am testing the template with the Meteobridge direct hardware upload. Is it possible to get the time stamps to format in 12 hour time (AM/PM)?
Chuck
Offline weather34
« Reply #23 on: March 13, 2017, 02:05:02 AM »
Brian
hello
well lets see what develops , it is purely down to the guy at meteobridge think we established that  Wim van der Kuil solution was just perfect as the template required absolutely no change so I guess in the near or far future it will happen. it shouldn't be to difficult so far no issues have been raised .
brian
Offline weather34
« Reply #24 on: March 13, 2017, 02:08:13 AM »
Chuck
firstly
and sure you can edit the settings.php also date format and think sometime in April ill add the option to set via easyweathersetup.php
settings.php
$dateFormat         = 'd-m-Y'; // date format to use when showing dates use m-d-Y usa format or europe etc d-m-Y for default
$timeFormat         = 'H:i:s'; // time format to use when showing times ('g:i:s a' for '5:34:22 pm', 'H:i:s' for '17:34:22')
$timeFormatShort    = 'H:i'; // time format to use when showing times ('g:i a' for '5:34 pm'; 'H:i' for '09:28')
brian
