Update because this didn't fix the problem I've removed the nighttime panel and added a second Davis solar panel wired parallel facing SW.
Dead of winter getting less than 7 hrs. of charge time peaking around 450 W/m2 and then you add a couple of cloudy days the 2 C-cell FARS batteries just won't last the night, hopefully, this takes care of it or I'll be going back to the AC fan mode when the ground thaws and I can run conduit. Something I was trying to avoid by going solar
Something I experience often during winter using just 2 C-cell batteries after a couple of days of clouds and snow the solar fan will stop at night causing above normal temps due to lack of airflow being drawn into the 24 hr. shield and across the sht31 sensor.
The solution I've come up with is using a secondary panel that automatically comes on (dusk to dawn) type.
I've only tested this one night so far with great results. This morning at 7F I could hear the solar fan making that distinctive swirling sound it normally only makes under full sun.
Do this mod at your own risk: Like I said this has only been tested for 1 night.
It's a simple mod only takes wiring into the existing Davis solar panel. Make sure the polarity is correct or the fan will stop or reverse. Voltage off the panel is 3.7 volts but adjust once wired into around 2.1 volts so it shouldn't fry the solar fan. Voltage should drop to the Davis panel output voltage by default.
You can test by covering the new panel photocell sensor and forcing the panel on and test voltage, also check polarity once plugged in you will know if the fan spins backward or stops.
These panels I've been using for yard spotlights and have proven dependable going on 3 years in a cold winter climate and no failures on the panel itself. The name brand has changed but found the same panels under a different manufacturer name I'll link.
I think the mythical VP3 should have something like this. Using 2 tiny C-cell batteries just doesn't cut it come wintertime.
https://www.amazon.com/Spotlight-Outdoor-Pathway-Driveways-Automatically-Activates/dp/B07CKRYJRM?ref_=ast_sto_dp&th=1 [ You are not allowed to view attachments ]
