Administration => WXForum Bugs/Suggestions => Topic started by: Scalphunter on December 15, 2016, 06:02:50 PM
Seeing how there is an Aviation section to weather forum how about adding an Marine weather section. lot of folks live along the coast line and has boats more then aircraft. You know that hole surrounded by water into which you pour money into.
Good idea, I personally would probably re-structure the threads completely, some sections that are directly on the homepage are absolutely unused
BOAT (Break out another thousand....) #-o
you don't know how true that is for large ships trying to stay up on all the ISO regs.
Never heard that one, but so true.
A "Marine Weather" topic section is exactly what I was thinking of suggesting here since before coming aboard, until I saw your post; 'like minds' and all that.
It's certainly as wide an interest area, and even NOAA devotes at least as many resources to "marine" interests as aviation (I would include the whole NHC as initially and primarily "marine" in nature).
Not to mention the FNMOC. Which has/had some fantastic data and imagery available ("had" because in the 'good ol' days' there was even more available before the site 'security' was tightened up). It also has perhaps the best world-wide cyclonic data and imagery available too.
Naval Oceanographic Portal - Public Facing: https://metoc.ndbc.noaa.gov/web/guest/fnmoc (https://metoc.ndbc.noaa.gov/web/guest/fnmoc)
