Somewhere in a previous post... can't remember which subforum... I detailed how I do it with ImageMagick...
This is the template I run in WeatherLink: (saved as a *.bat file) I used the multiple "set" statements because I was running into problems trying to create one long ImageMagick command line...
"convert" is the ImageMagick command...
set stationdate=<!--stationDate-->
set stationtime=<!--stationTime-->
set outsidetemp=<!--outsideTemp-->
set hioutsidetemp=<!--hiOutsideTemp-->
set hioutsidetemptime=<!--hiOutsideTempTime-->
set lowoutsidetemp=<!--lowOutsideTemp-->
set lowoutsidetemptime=<!--lowOutsideTempTime-->
set humidity=<!--outsideHumidity-->
IF EXIST capture_1.jpg convert capture_1.jpg -size 1x25 xc:Yellow -background Yellow -append -gravity South -pointsize 18 -draw "text 0,0 '%stationdate% %stationtime% Currently %outsidetemp%F Hi %hioutsidetemp%F at %hioutsidetemptime% Lo %lowoutsidetemp%F at %lowoutsidetemptime% %humidity%%% Humidity'" tagged\newimage.jpg
"capture_1.jpg" is the image file save by my P&S camera... the ImageMagick command creates a border at the bottom of the image with all those weather variables...
The resulting *.bat file then looks like this--with the data substituted:
set stationdate=03/16/08
set stationtime= 6:59p
set outsidetemp=59.9
set hioutsidetemp=62.3
set hioutsidetemptime= 4:05p
set lowoutsidetemp=53.3
set lowoutsidetemptime=12:46p
set humidity=52
I save the file in a directory that's being monitored by Fling, an FTP program that will watch a folder, and when a file appears, will FTP to wherever...
The batch file itself is run using Windows scheduler...
I believe ImageMagick will also create movies from single images...
And................. it's all free!
