Web Weather => Weather Website PHP/AJAX scripting => Custom Website Templates => Topic started by: txweather.org on April 21, 2019, 11:45:57 PM
I am trying to make the drought page from https://www.gwwilkins.org/wxdrought_maps.php
Work on my site but something is not loading and cant figure out what... I change all the links to https.
https://www.txweather.org/wxdrought.php
Ideas?
Ideas?
For reasons unknown to me the page is truncated at a height of around 680px. I can't figure out where the problem lies. Sorry... :-(
gwwilk,
Thanks for your reply.
Ill try and see whats going on... Ill keep digging.
<div id="drought" class="frame_border center" style="width:662.09302325581px; height:496.56976744186px; position:relative">
<a href="https://droughtmonitor.unl.edu/data/png/current/current_total_trd.png" target="_blank" title="Larger Map"><img src="https://droughtmonitor.unl.edu/data/png/current/current_total_trd.png" alt="" width="680"/>
The above in bold will make the image appear, then you should be able to finish the page out from there.
Note too sure what to change... Its all in there like what you have except with variables...
I moved the page to https://wxdev.txweather.org/wxdrought.php
Found my problem...
I had to change the script:
if (!function_exists('getUniqueImageURL')) {
function getUniqueImageURL($image_url){
$timestamp = time();
if(strpos($image_url, '?')){
$image_url = str_replace('?', "?$timestamp&", $image_url);
else{
$image_url .= "?$timestamp";
return $image_url;
to
else{
return $image_url;
Glad you got it sorted out. That has been an issue for some others as well, and obviously I'm not sure why. The function-check prevents a duplicate function error, but ironically for some it causes an error instead. Sorry...
Nothing to be sorry about, Thank you for your awesome work!
