Author Topic: Tipping bucked Sesnsing Metode  (Read 1045 times)
Offline bayu
« on: July 08, 2011, 11:19:29 PM »
according with first picture :
a: Rain Collector
b: Magnetic load
c: Sensor Mounting
d: Out put magnetic pick-up sensor
Picture 1 is position 1
Picture 2 is position 2
Picture 3 is position 3
Picture 4 is Sensing Mode
Picture 5 V-out off magnetic pick-up sensor
Picture 6 Sensing diagram
magnetic pick-up sensor work like lamp switch at home, using binary logical value: 0  and 1, 0 as off logic and 1 is on logic
when magnet pass trough sensor, sensor will be reacting changing logical value from zero to one,
or we can say
Pict 1 out sensor = 0 (off)
Pict 2 out sensor = 1 (on)
Pict 3 out sensor = 0 (off)
picture 4 to detail,
from that argument out logical value will count in  ram or memory register using interrupt port and summarize value and multiply by 0,2 mm
using timer interrupt signal,
Sorry about my English if you don't understand about my topic just ask or quote
Re: Tipping bucked Sesnsing Metode
« Reply #1 on: July 09, 2011, 12:21:50 PM »
Bayu,
Is the sensor a "Hall Effect" device? What type did you use?
Allegro Microsystems makes some. http://www.allegromicro.com/en/Products/Part_Numbers/1101/index.asp
This might be an improvement over the reed switch. Allegro claims ESD and EMI robustness.
Have you had good results with the sensor instead of a reed switch?
Greg
