Author Topic: Winter '16-'17  (Read 57824 times)
Offline zackdog
    • Winter Park Highlands Web cams
Re: Winter '16-'17
« Reply #325 on: January 06, 2017, 10:11:01 AM »
Storm lasted three days and was not too bad for me, except for the wind.  I got 11" out of the storm, while Winter Park ski area got 28".  They are about ten miles SE of me.  Snow stopped late yesterday afternoon along with the wind, so I went out to blow out the driveway.  I got the drive cleaned out but did not clean up the turnaround or behind the truck.  The job took an hour and ten minutes, which is almost a half hour longer than it would when it was not wind packed drifted snow.  About half of the drive had 18" drifts all the way across it.
It is supposed to be sunny today, so when it warms up, currently -15° F, I will go finish blowing snow.
"You don't need a weatherman to know which way the wind blows." - Dylan
Vantage Pro2 Plus w/ 24 hr FARS and (2) VantageVues
VP2 uploading via Vue console to CWOP, WU, PWS, and Weathercloud.
Offline Scalphunter
Re: Winter '16-'17
« Reply #326 on: January 06, 2017, 01:05:20 PM »
Good morning from an balmy  25 below and under an record barometer for the year. Barometer reading 31.10. This intense pressure if hangs around will tip us over the edge to hit -40 F/C. Saturday nite one forecasted showed -37.  Hooray maybe winter finally got here.
Re: Winter '16-'17
« Reply #327 on: January 06, 2017, 02:14:07 PM »
It snowed about an inch in Stillwater last night, enough to close schools.  Plenty cold enough for the snow to stick. Scene from my back door.  Oklahoma City got around 3 inches.  Low expected Saturday morning around 4.   It will be interesting to see what the snow does in the South.
http://www.stwnewspress.com/news/residents-wake-up-to-blanket-of-snow/article_c7935f1e-c96c-5ff4-be3e-eccce24ca46f.html
« Last Edit: January 06, 2017, 02:27:46 PM by Bunty »
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
Re: Winter '16-'17
« Reply #328 on: January 06, 2017, 03:51:40 PM »
Temperature starting to  slide  towards -30 which is forecasted for Friday night as an 1057 mb  parks itself  over head. Barometer is at 31.83 in/hg  at the present and climbing. Been  blowing all day as the  temps  dropped  during the day.  Lot of fresh blowing snow  to move where  the over night  dump and blowing snow filled back in the  dooryard.  fired up the little orange  tractor and  started moving  it by the  bucket full. Couple hours later  cleared out  the dooryard and  cleared some of the road in front of the property.  Our road is not an high priority on the state plowing  list.
Wow.  31.83.  I would have a massive headache by that point, because when it got up to 31.02 about two years ago and lasted for a day or so I was miserable.  I couldn't believe pressure could do that but my PCP told me he'd seen several people who were complaining about headaches.  That's high pressure right there.
Weather radios:
Reecom R-1650
Sangean CL-100
Uniden Home Patrol I
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
Re: Winter '16-'17
« Reply #329 on: January 06, 2017, 03:53:26 PM »
Yeah, this is what it looked like from my front porch this morning about 8am:
Weather radios:
Reecom R-1650
Sangean CL-100
Re: Winter '16-'17
« Reply #330 on: January 07, 2017, 08:41:23 AM »
Finally some decent rain last night. 2.96. That's more then the last 3 months combined. Was woke up about 2:30 last night as the weather radio was going off. Jacksonville said there was rotation in the storm but it just turned out to be a good rain maker.
Temps and dews are crashing behind the front. Will be a cold stretch for us the next couple days.
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
Re: Winter '16-'17
« Reply #331 on: January 07, 2017, 10:17:40 AM »
Just came back from Prague, it was -17C (1F) last night. Now the sun is about to set in an hour and it is much colder than this time of the day yesterday so it is likely to drop even lower tonight :)
Re: Winter '16-'17
« Reply #332 on: January 07, 2017, 12:13:39 PM »
Temps dropping fast here. Now in the upper 40's.
Quite a range of temps in the state. From the 20's in the panhandle to 80's down south.
Indeed a strong cold front.
Those 20's and 30's in the panhandle are 12:00 EST temps. Not sunrise temps.
« Last Edit: January 07, 2017, 12:15:30 PM by ocala »
Offline Jáchym
    • Meteotemplate
Re: Winter '16-'17
« Reply #333 on: January 07, 2017, 12:25:55 PM »
Temps dropping fast here. Now in the upper 40's (4C).
Quite a range of temps in the state. From the 20's (-7C) in the panhandle to 80's (26C) down south.
Those 20's (-7C) and 30's (-1C) in the panhandle are 12:00 EST temps. Not sunrise temps.
 ;)  Dont forget about us Celsius guys ;)
« Last Edit: January 07, 2017, 12:30:52 PM by Jáchym »
Re: Winter '16-'17
« Reply #334 on: January 07, 2017, 12:43:19 PM »
Wow, more than just a few below zero lows Saturday morning in Oklahoma.  Two locations in Oklahoma had -12(-24C) for the lowest.  I had 4 (-15.5C).  Most Stillwater area WU stations were just above zero,(-18).  Back to the 60s on Tuesday.
« Last Edit: January 07, 2017, 12:55:56 PM by Bunty »
Re: Winter '16-'17
« Reply #335 on: January 07, 2017, 12:45:16 PM »
Your right. I keep forgetting. I need to print out a F/C chart so I remember.
Offline Jáchym
    • Meteotemplate
Re: Winter '16-'17
« Reply #336 on: January 07, 2017, 01:05:25 PM »
Thanks! I actually personally dont really care, given how much time Ive spent with all this in the past year and half and given I work with both units Im now quite familiar with both and have an idea of what is "really cold" etc. but for the world outside US it is usually (not the case of all) completely alien
Re: Winter '16-'17
« Reply #337 on: January 07, 2017, 01:12:38 PM »
Barometer just hit 30.702 inches
not the highest ever recorded by me, but high.
At least it is up to 6F
« Last Edit: January 07, 2017, 01:16:27 PM by chief-david »
Offline Jáchym
    • Meteotemplate
Re: Winter '16-'17
« Reply #338 on: January 07, 2017, 01:59:57 PM »
Here you can see nicely the differences we have now here, the entire continent is well below average, but part of it (including my country) is now influenced by the very cold arctic front that moved in to the central EU area, my country is right at the tip of the purple area.
Offline Scalphunter
Re: Winter '16-'17
« Reply #339 on: January 07, 2017, 05:34:18 PM »
Mid day sun today. Not much warmth from it. Not high enough to register solar data.
Offline alexstaar
Re: Winter '16-'17
« Reply #340 on: January 07, 2017, 06:00:02 PM »
Very cold day here in northern Alabama, USA today. Low this morning at my place was 13.1ºF (-11ºC) with an afternoon high of 25.9ºF (-3ºC) under clear and sunny skies. Not a cloud to be seen. Expecting an all time record high pressure at my place tomorrow morning. Current record is 1043.08 mb; expecting at least ~1044 mb by tomorrow morning. That's very high for this far south. Normal strong high pressure is in the ~1035 mb range. P.S. - I'm a meteorologist so I don't like using inHg  ;)
-Alex
Davis 6153 VP2 with 24-hour FARS/
Davis 6250 Vantage Vue
WU: KNJMOUNT68/KSCGREER81
CWOP: FW5135/EW6390
www.uah-mcthornmoracres-weather.com
Re: Winter '16-'17
« Reply #341 on: January 07, 2017, 06:14:35 PM »
But the other 99.9% of us do. :-P
Offline WheatonRon
    • WUnderground
Re: Winter '16-'17
« Reply #342 on: January 07, 2017, 06:16:15 PM »
Yep. Mbs doesn't mean anything to me! It is even worse than centigrade! At least i can easily convert centigrade to farenheit!
« Last Edit: January 07, 2017, 06:25:57 PM by WheatonRon »
Offline Jáchym
    • Meteotemplate
Re: Winter '16-'17
« Reply #343 on: January 07, 2017, 06:20:26 PM »
You mean 99.9% of Americans dont you, Im ok with it :D I.e. 99.9% of negligible 4% of world population :D :D
Just kidding ;)
1043 hPa = 30.79 inHg
1044 = 30.82
1035 = 30.56
« Last Edit: January 07, 2017, 06:22:04 PM by Jáchym »
Offline alexstaar
Re: Winter '16-'17
« Reply #344 on: January 07, 2017, 06:26:58 PM »
Just kidding ;)
1044 = 30.82
1035 = 30.56
I suppose I could have converted the units... Oh well! Thanks for doing that for me  :-)
-Alex
CWOP: FW5135/EW6390
Re: Winter '16-'17
« Reply #345 on: January 07, 2017, 06:32:46 PM »
I do. After all, we did invent weather. :grin:
Offline Jáchym
    • Meteotemplate
Re: Winter '16-'17
« Reply #346 on: January 07, 2017, 06:32:56 PM »
Farenheit... sometimes I just keep asking myself why :D
I understand you guys are now used to it, but why in the first place was C not introduced long time ago just like in... just like in any other country :D
Offline Jáchym
    • Meteotemplate
Re: Winter '16-'17
« Reply #347 on: January 07, 2017, 06:34:15 PM »
Interesting concept :D I guess I always thought weather was "invented" by the law of physics :D
Re: Winter '16-'17
« Reply #348 on: January 07, 2017, 06:35:11 PM »
Offline ValentineWeather
Re: Winter '16-'17
« Reply #349 on: January 07, 2017, 07:00:16 PM »
Why because it has more integers and Fahrenheit is superior for measuring temperature precisely. We got it right the rest of the world screwed up IMO.
http://www.zmescience.com/other/fahrenheit-vs-celsius-did-the-u-s-get-it-right-after-all/
Randy
