I know some of you may think I should be posting this on the Weather Display Forum. However, I would like to start my exploration by getting some inputs from those of you on this forum first.
After ten years of running VWS, I have just about had it with VWS, VVP and VPLIve issues. Since I moved to a new laptop, I have had nothing but continuous problems with my website and the software feeding it. I keep losing VVP connections with both VWS and VPLive. I have tried everything I can think of to get things to stay connected and run as they should (and used to).
So, I am at the point now that I am going to go to some other software and most likely that will be Weather Display. I have a license for it and have had one for many years but never put it to use. I have a couple questions that perhaps someone here can answer. If not, I'll post them on the WD forum later.
I am currently using StartWatch to control my programs which are VVP, VWS, WL, VPLive and Image Salsa.
My main question is "What do I need to do to switch from VWS to WD?" Are there step-by-step instructions on doing this and, since I have 10 years of history data, will I be able to somehow import that old data into WD? I am using Ken's templates as well as the old original VWS templates for my website and I would really like to keep Ken's template as is. I know there are differences in the tags used by WD and VWS.
Hopefully, others have gone through this and kept some kind of a step-by-step process to make the migration a bit less painful. I suspect this will take quite some time to get it done, and to learn the in's and out's of WD.
Any suggestions, pointers to other similar discussions, etc are most greatly appreciated.
EDIT: I should have mentioned that I have a Davis VP2 wireless station.
