The clue is already in weather34's first answer, i think.
Comparing your "realtime MB upload file" with the api file from weather34's post there is one field extra in your upload. The uploaded file contains 127 fields, it should be 126. An extra space (and text) is generated in fields [40] to [43], which are specified in the template file as[wind0wind-max10:--]
[mbsystem-platform:--]
[mbsystem-station:--]
[uv0index-act:--]
And they are uploaded as 0.9 CARAMBOLA2 Meteostick Vantage --
After the "explode (' ', $.... )" that results in 0.9
CARAMBOLA2
Meteostick
Vantage
I think that this is a problem for Boris, the meteo* author.
Probably " Meteostick" is added by the Meteobridge software to the computer name (or station name) but for usage in this API that space should be replaced by an underscore or similar.
The result of that extra space is that all data after field [43] contains incorrect information. So all data and time fields will contain "rubbish" also.
Wim
