Author Topic: 5 in 1 temperature issues  (Read 1158 times)
Offline karss
« on: August 19, 2018, 01:27:27 PM »
Off late my 5 in 1 sensor is giving occasional low temperature spikes (-17.8C), does that mean my temperature sensor is dying?
Offline nincehelser
Re: 5 in 1 temperature issues
« Reply #1 on: August 19, 2018, 01:31:45 PM »
Do you ever see those low temperatures on your display, or is it only on the myAcurite graphs?
Offline karss
« Reply #2 on: August 19, 2018, 02:02:28 PM »
I see it on Weather Underground, but myAcurite Dashboard doesn't show these spikes. These were just random spikes I could not notice it on the display, I did transfer the data from the display to computer using PC Connect, there too I don't see this spike. It's seen only on WU.
Offline DoctorKnow
« Reply #3 on: August 19, 2018, 02:27:43 PM »
I think it is your PC connect display. Try a reset of the display.
Offline karss
« Reply #4 on: August 20, 2018, 03:50:20 AM »
@DoctorKnow, I use a SmartHub to report data to Weather Underground, do you suspect a SmartHub issue? I will reset the SmartHub and check.
Offline DoctorKnow
« Reply #5 on: August 20, 2018, 08:50:41 AM »
No, I doubt a smarthub could do that error. You will need to open up the 5n1 and check it.
Offline karss
« Reply #6 on: November 04, 2018, 06:15:57 AM »
I just noticed that these -17.8C events occur during a router reset or smarthub reset or during power failure, when both the router and smarthub gets reset. It doesn't happen every time when a router/smarthub resets, seems like a random event triggered by as yet unidentified cause.
