Author Topic: Cant get to work GR3-radar-inc.php and advforecast2.php scripts in the same page  (Read 996 times)
Offline Gerry0587
I'm trying to have both scripts in the same page but the GR3-radar-inc.php script won't work and gives me the "GRLevel3 radar images are not available at this time" message. However, when I try the GR3-radar-inc.php in a page without the advorecast2 script it works flawlessly.
Any help will be greatly appreciated.
Online saratogaWX
That shouldn't be a problem.. on a copy of wxnewpage.php, just have the main content be
<div id="main-copy">
<h1><?php langtrans('GRLevel3+advforecast2'); ?></h1>
<p>&nbsp;</p>
  <?php @include("radar-status.php"); ?>
  <?php include_once("GR3-radar-inc.php"); ?>
<hr/>
<?php
   $doIncludeNWS
true;
 $doPrintNWS   true;
 include_once("advforecast2.php");
</div><!-- end main-copy -->
and it works fine (see https://saratoga-weather.org/wxtemplates/USA/wxgr3fcst.php for an example)
Offline Gerry0587
Hi! I just tried that but it gives me the message: "GRLevel3 radar images are not available at this time."
http://weatherpr.com/wxnewpage.php
However in this page it works perfectly:
http://weatherpr.com/testindex.php
Online saratogaWX
In the wxnewpage.php, you're asking for CR type images (which are not uploaded to your site).  In the testindex.php you're asking for BR images (which are found).
Offline Gerry0587
I just checked and I have the $GR3type= 'br' in the "GR3-radar-inc.php" file used in both pages...
« Last Edit: June 19, 2018, 11:36:59 PM by Gerry0587 »
Online saratogaWX
In the Settings.php, you have
$SITE['GR3type']    = 'cr';        // radar image type 'cr','br','cr248','br1' etc.
which overrides the $GR3type setting in the script (when included in a template page).
Change Settings.php to have
$SITE['GR3type']    = 'br';        // radar image type 'cr','br','cr248','br1' etc.
and wxnewpage.php should work also.
Offline Gerry0587
Perfect! That worked out!! Very grateful!
Online saratogaWX
You're welcome!  If you download https://saratoga-weather.org/saratoga-icons2.zip , unzip and upload it all to your site, then the dual-image processing will work on your forecast from the NWS.
The .zip has:
DualImage.php
./forecast/images
./forecast/icon-templates
so be sure to upload them to those positions (DualImage.php in document root, others in the subdirectories listed).
Also.. http://weatherpr.com/check-fetch-times.php?show=versions shows you have some updates to do :)
Offline Gerry0587
Thanks for the tips!  :-)
