Rob, based on you profile you live in Gulfport, Florida so I suspect that Johnd is correct with moisture being the culprit. With warmer days and cooler days being perfect conditions for condensation (inside the VP and outside too) that can cause corrosion of the plugs and receptacles inside the SIM box. The other thing to check carefully is to make certain you don't have a leaky antenna. The rubber covering on the Davis VP has been known to get cracks which will allow rain and moisture to get inside and flow down into the SIM box. You haven't said how old your VP2 is but I know they did make updates to the antenna itself a while back due to leaks.
