Author Topic: Weatherlink update data  (Read 1111 times)
Offline Guillaume_67370
    • METEO OFFENHEIM
« on: April 03, 2018, 02:34:37 PM »
Hello,
Is it possible to adjust the time in second when the weather data will be updated.
Of course at this time often the update will be done at the minute + 5 seconds and the data i receive are the data from minute - 1.
So if it will be possible to update the data all minute + 15 seconds so 10 second later, it will be the weather data from the minute m.
For example : On 20:29:05, i receive the data (temp, wind, humidity...) from 20:28 and on 20:29:15 the data from 20:29
Did you also have this issue ? Can we do something on that ?
Thanks for your great help
Offline johnd
Re: Weatherlink update data
« Reply #1 on: April 03, 2018, 02:46:51 PM »
Sorry, I don't really understand what you're asking, but the answer is likely to be no - you can't control the timing.
But is this local Weatherlink for Windows you're asking about? Is it archive data maybe at a 1-minute interval or the real-time/loop data? More details would be helpful in understanding the question.
Cambridge UK
Offline Old Tele man
  • Singing in the rain...
« Reply #2 on: April 03, 2018, 03:54:35 PM »
ISS can have a different internal "timing" than does the Console that's reading the ISS signals. There's no (current) way to synchronize them.
Offline dalecoy
    • Lee's Summit, MO
« Reply #3 on: April 03, 2018, 04:50:17 PM »
As far as I know, the ISS has no idea of what date/time it is.  The ISS just sends measurements to the console, where the logger picks up the data at the logging interval (including the time-stamp of the data).
If software gets the most recent saved data at 20:29:05 - but the most recent data came in at 20:28, then reporting it as if the data came in at 20:29 would be a lie.
Of course, it would be possible to write software that receives the output from the ISS directly (eliminating the console and logger), and then immediately displays the data on the computer monitor.
[That could be called firmware and console display]
    • METEO OFFENHEIM
« Reply #4 on: April 04, 2018, 07:16:20 AM »
Thanks for your answer
What do you mean about : ISS can have a different internal "timing" than does the Console that's reading the ISS signals ??
So as i understood you have also this problem ? and there is no solution to solve them
Online Mattk
« Reply #5 on: April 04, 2018, 08:53:52 AM »
So is there actually a problem here? Especially considering no data is sent or received every second anyway.
Offline dalecoy
    • Lee's Summit, MO
« Reply #6 on: April 04, 2018, 11:36:16 AM »
In my opinion, it is not a problem.
On 20:29:05, i receive the data (temp, wind, humidity...) reporting the most recent available measurements which were made at 20:28 and
on 20:29:15 the data from the most recent available measurements which were made at 20:29
Perhaps Old Tele man will explain what he meant by that.
    • METEO OFFENHEIM
« Reply #7 on: April 04, 2018, 11:39:24 AM »
I would like to know if the user of weatherlink have the same think or if it is an issue on my side...
And that would say i will always transmit data from the minute before on my website, so that is a little bit annoying for visitors...
Offline dalecoy
    • Lee's Summit, MO
« Reply #8 on: April 04, 2018, 11:55:11 AM »
Why are you worrying about data sync, when the time on your console is more than 2 minutes incorrect?  [2 minutes behind GMT]
When I looked at your site at 17h55, it was showing the time as 17h52.
« Last Edit: April 04, 2018, 12:04:06 PM by dalecoy »
    • METEO OFFENHEIM
« Reply #9 on: April 04, 2018, 12:13:42 PM »
I think 2-3 minutes is very long before i had only 1 minute maximum.
Do you think it can also be a problem with caching issue with my web server ??
See the gauge, more particulary the wind, http://www.meteo-offenheim.fr/instruments.php
data will be updated only every 20-22 seconds instead of 9 seconds before..
« Reply #10 on: April 04, 2018, 06:29:25 PM »
The ISS operates from its own hardware "clock" timing, it does not have a oscillator-controlled Real Time Clock (RTC: TIME & DATE) chip as exists in the Console. Hardware clocking runs at a designed-in frequency without regard to any correlation to actual TIME & DATE timing.
