Author Topic: Issues with MB and twitter ***SOLVED***  (Read 1624 times)
Offline josecmorales
« on: October 29, 2017, 06:26:13 PM »
Few days ago the electricity went down for a few minutes, when the electricity returned the MB was deconfigured, im trying to setup again but have an issue with the twitter, the system say this:
Error: la autenticación de Twitter falló: sed: can't create temp file '/root/mytwit.shwASr4u': No space left on device
Error: Twitter feed de Meteobridge aún no autorizado
What happened here?
« Last Edit: November 04, 2017, 03:44:28 PM by josecmorales »
Vantage Pro2 + UV, Airlink, Purpleair, Meteobridge.
Twitter: ClimaGuayana
Blitzortung station: 2934
Weatherlink: ClimaGuayana
Offline docbee
  • Moderator
    • smartbedded
Re: Issues with MB and twitter
« Reply #1 on: October 30, 2017, 07:26:42 PM »
When reset to factory defaults does not cure the problem you might have a slightly defective internal flash in the MR3020.
« Reply #2 on: October 31, 2017, 07:33:03 AM »
...you might have a slightly defective internal flash in the MR3020.
I think this is the problem, because i reset it 2 times!, is this issue have any solution to this?
Offline docbee
  • Moderator
    • smartbedded
« Reply #3 on: November 01, 2017, 05:04:05 PM »
Did you do the "5 blink reset to factory defaults"? Simple reset won't do.
« Reply #4 on: November 02, 2017, 04:09:30 PM »
No, i didnt, would you mind to guide me?
« Reply #5 on: November 02, 2017, 04:45:21 PM »
« Reply #6 on: November 04, 2017, 03:43:54 PM »
Thanks a lot, works fine again.
