Author Topic: Looking for help with meteobridge and dir 505 setup.  (Read 793 times)
Offline rooster
« on: September 19, 2017, 09:50:07 AM »
Hey everyone
My dir 505 came in a few days ago.
I flashed the dir to meteobridge, connected it to My router, got the IP and configured it.      When I unplug the 505 from the router, I can no longer find it via IP.  I went over everything over and over again, then decided just to unplug the router and 505 for a little bit.    Now, when I plug everything in, nothing works.  I can't even get to my router settings with the 505 plugged in.  I can't use Wi-Fi at all with the 505 plugged in.    As soon as I unplug the 505, the router works again.
Any ideas how to fix this and how I can get it working?   I would be more than happy to start over, but I don't know how to re flash it.
Offline wvdkuil
  • Wim van der kuil
Re: Looking for help with meteobridge and dir 505 setup.
« Reply #1 on: September 19, 2017, 12:00:27 PM »
Hey everyone
http://meteobridge.com/wiki/index.php/Boot_Sequence
This explains the boot-sequence and how to reset the MB back to as it was after the flash.
Then you can start over at  "got the IP and configured it. "
If you do not want to have it cabled to your router you should set it to use your WLAN
http://meteobridge.com/wiki/index.php/Setup_Network
Do not set it to  a fixed IP address but use DHCP, that way you can always find it.
This link will always work when you do not know the ip:  http://magicip.meteobridge.com/
It shows all MB devices in your LAN, more info http://meteobridge.com/wiki/index.php/Getting_Started
Flash Again is described at the bottom of this WiKi page:
http://meteobridge.com/wiki/index.php/Preparing_Hardware
Succes, Wim
Offline rooster
« Reply #2 on: September 19, 2017, 12:26:22 PM »
Thanks for the info!!      I did set it to WLAN.  That was sort of my issue.   My problem was, I didn't realize it actually was working properly, but I had it set to WLAN (like I wanted), but still had it wired, so that caused my issues.  Working now!  Thanks!!
