Author Topic: HOMEWEATHERSTATION Dashboard template  (Read 63156 times)
Offline prestwickwx
Re: HOMEWEATHERSTATION Dashboard template
« Reply #575 on: June 03, 2018, 01:07:41 PM »
Brian,
I hope your roof repairs are going well.
The Dark Sky API looks great - a good substitute for WU. Will the latest release of the stationcron.php support Curl? I believe I am presently using a custom version you sent me.
Take care.
Chuck
hi all API calls are now curl based now as more and more hosts are disabling fopen/ by default so
example but all are almost identical apart from url..
// weather34 darksky  curl based
$url4a = 'https://api.forecast.io/forecast/'.$apikey.'/'.$lat.','.$lon.'?lang='.$language.'&units='.$darkskyunit ;
$ch4a = curl_init($url4a);
$filename4a = '../jsondata/darksky.txt';
$complete_save_loc4a = $filename4a;
$fp4a = fopen($complete_save_loc4a, 'wb');
curl_setopt($ch4a, CURLOPT_FILE, $fp4a);
curl_setopt($ch4a, CURLOPT_HEADER, 0);
curl_exec($ch4a);
curl_close($ch4a);
fclose($fp4a);
Great! Just updated and the Dark Sky API is working fine. I did notice one possible bug in the UVI-SOLAR Panel. When the Solar Radiation reaches 1000 W/M2 the Panel bar graph shows it as 1.
Still waiting for the WeatherFlow!
Best wishes,
Chuck
Offline weather34
  • its just my hobby
    • Sinanoba Istanbul Home Weather Station
« Reply #576 on: June 03, 2018, 02:34:56 PM »
sorry its a short reply all fixed just replace livedata.php from download, i have to go an meet my wife at the airport ...ps download was updated with new air quality provider ..if air quality is of interest...other than that its the same..
Offline prestwickwx
« Reply #577 on: June 04, 2018, 08:17:35 AM »
Got it. Thanks for the fix!
Chuck
Offline bianconero57
    • Valdefensch@57
« Reply #578 on: June 04, 2018, 10:27:44 AM »
good evening Brian yes thank you i saw that everything seems ok for my second station  :-)
by cons, this morning, doing the same update for my first station, as a habit i still have the two modules that remain "off"
**Forecast and ** Current conditions
while i edited my easy_weathersetup ?
http://valdefench57sgz.franceserv.com/pws/index.php
Regards
Offline weather34
  • its just my hobby
« Reply #579 on: June 04, 2018, 03:07:21 PM »
hello fixed , you had not set the language option for the forecast so the dark sky api was returning this
{"code":400,"error":"An invalid lang parameter was provided."}
also corrected your utc offset ... dont use +2 just use 2
brian
Offline weather34
  • its just my hobby
« Reply #580 on: June 06, 2018, 01:13:33 AM »
good morning
*please note it is only my personal weather station site that is private the download page is available as normal. sorry if i dont reply to all the pm or emails about this ..
if your ip is blocked then i apologize but simply means an ip,address within the same range was scraping my personal weather site every 5 seconds , i recieved a warning email from host of excessive cpu continous useage , after they investigated they came back with ip adresses from europe those were i czech rep and in holland.
simply blocking the ip,adresses is not always sufficient has the culprits can go vpn hopping so hence the password protect. do not take anything personal or assume its anything else , it simply is what it is as stated above.
download page
https://weather34.com/homeweatherstation/
the url is also in my signature
« Last Edit: June 06, 2018, 01:16:59 AM by weatherist34 »
Offline prestwickwx
« Reply #581 on: June 07, 2018, 02:55:37 PM »
Brian,
Just uploaded your latest with the AirVisual AQi. The Air Visual API seems to work much better than the previous one. Your re-work of the css on the Hourly Forecast and Forecast Summary (Dark Sky) look great! I did notice that in the previous version the Hourly Forecast time increments were formatted in 12 hr. time and new version is in 24 hour. Not a big deal, but I thought I would let you know.
Best Wishes,
Chuck
« Last Edit: June 14, 2018, 08:49:36 AM by prestwickwx »
Offline Ryan
« Reply #582 on: June 09, 2018, 03:37:35 PM »
So I'm trying to work through getting this set up. Never done this sort of thing before. I have a couple issues.
Where is the download that contains the mbx5-mysql-setup.pdf?
And when I am seeing the following error on the main page and a couple other places.
Warning: ini_set(): Headers already sent. You cannot change the session module's ini settings at this time in /srv/users/serverpilot/apps/pws/public/settings.php on line 83
Offline Naxx
« Reply #583 on: June 10, 2018, 05:06:38 AM »
CURRENT AIR QUALITY INDEX not working for me why?
http://www.pogodakielczow.com.pl/?theme=dark
Offline Ryan
« Reply #584 on: June 11, 2018, 11:09:17 PM »
So I was able to get rid of the error by removing "ini_set('session.use_cookies', '0')" from line 83 of the settings file!
But I would still appreciate it if someone could point me to "the download" and PDF that are reference on the setup page. https://weather34.com/homeweatherstation/guides/setupmeteobridge.html
Offline weather34
  • its just my hobby
« Reply #585 on: June 12, 2018, 06:00:56 AM »
you need to contact mystic_art he maintains that version for WS1001 and provides the polish translations..
Offline Mystic_Art
« Reply #586 on: June 12, 2018, 06:03:06 AM »
Everything is ok.
I contacted with him and sended corrected version of this module
Wysłane z mojego SM-G935F przy użyciu Tapatalka
Offline weather34
  • its just my hobby
« Reply #587 on: June 13, 2018, 02:29:56 AM »
hello Ryan
im sorry I tried to reply yesterday but my 3g connection kept timing out so anyway there is not a PDF that is my mistake originally there was but it is basically a replica of what you see on the web page , the pdf added an extra 1.5mb of download size so i just create a web page so i sincerely apologize for the misinformation and feel free to email me any time Im stuck at home for the foreseeable future overseeing a roof construction and decorating after fire..
on another note I had a few requests for a way of using the new wifi logger for Davis console the short answer is at the moment NO possibly with some collaboration with the developer and a few users it could be done . However a big however good old trusted Boris at meteobridge as announced is own solution to this and requires no change in template as far I am aware at the moment and has all the hallmarks of the familiar meteobridge features .
see more information about Meteobridge Nano here ... http://meteobridge.com/wiki/index.php/Meteobridge_NANO
brian ...
Offline stewart45
    • Newlands Weather Station
« Reply #588 on: June 13, 2018, 09:00:51 AM »
Meteobridge Nano looks interesting anyone know where it can be bought and how much
Offline Ryan
« Reply #589 on: June 13, 2018, 10:16:52 PM »
hello Ryan
brian ...
No worries. I will send you an email this weekend.
Offline Ryan
« Reply #590 on: June 13, 2018, 10:18:19 PM »
"Meteobridge NANO is planned to hit stores of established resellers in August 2018. Price still to be decided."
I will definitely be buying one if the price is reasonable.
Offline stewart45
« Reply #591 on: June 14, 2018, 03:43:49 AM »
Yes me to, price will be the deciding factor
Offline prestwickwx
« Reply #592 on: June 14, 2018, 08:38:58 AM »
hello Ryan
brian ...
The nano looks interesting. It would eliminate the distance issues associated with the present Meteostick and do away with the Meteobridge router. Since, the Davis wireless communicates over much longer distances than the "Stick".
Chuck
Offline bettsr67
  • Just BE NICE! That's all it takes to be a decent h
    • LOBWX
« Reply #593 on: June 18, 2018, 08:41:19 PM »
Hello all,
I just put up your template on my Raspberry PIB3+ a couple of days ago. The RPI works fine PHP 7.0.27-0+deb9u1,  Linux,  Zend 3.0.0; MySQL 5.5.5-10.1.23-MariaDB-9+deb9u1; Apache2 / 2.4.25, etc. My Station is the Ambient WS1401 IP hooked up to Meteobridge all working fine as well.
I have a few of questions for you fine people.
1. In the current conditions block I want to use METAR for my area KSBP. I have the API key from CheckWX but it only will show Istanbul, Turkey? Thanks Ryan
2. In the Forecast block nothing is there and it is reading offline. I do have the API key from DarkSky entered in the easyweathersetup.php Thanks Ryan
3. Total rain fall for 2018, 25.4 inches? Where is the template getting this number from?
Here I am on the world wide PI http://bobspib3.com/pws
~Bob~
« Last Edit: June 18, 2018, 10:24:34 PM by bettsr67 »
Offline Ryan
« Reply #594 on: June 18, 2018, 08:57:08 PM »
Hello all,
~Bob~
Doing the first section of Part 2 should fix the issue with the API data not updating. Same thing happened to me. https://weather34.com/homeweatherstation/guides/setupmeteobridge.html
Offline bettsr67
    • LOBWX
« Reply #595 on: June 18, 2018, 10:28:45 PM »
Thank You Ryan that worked on Issue 1 & 2 for me. I did not have the correct directory name /mbdbfiles i had /mdbfiles.
Offline tomipasin
« Reply #596 on: July 05, 2018, 02:25:40 PM »
Hi everybody!
I'm facing some problems with my Weather34 template to Cumulus.
All information and comunication is OK but sometimes the "feels", "Wet bulb", "humidity" and "Dewpoint" don't show information and appears aour of order, as show below:
When the correct is as follow:
Offline gand
« Reply #597 on: July 22, 2018, 12:18:49 PM »
Hi
I have just installed the Meteobridge/MySql version.
Is there any way to import data from WU(month/year data), before I close down my account?
gand
Offline Ryan
« Reply #598 on: July 22, 2018, 12:44:51 PM »
Hi
gand
Put the Weather History section into "Yearly Mode" then click on the Table tab. There's a download button in the top right corner of the table.
I would keep the WUnderground up and running personally. I still look at it on my phone so that I can see the graphs.
Offline gand
« Reply #599 on: July 26, 2018, 01:22:24 AM »
Hi
Thanks for the proposed solution.
As far as I can see, there is a difference in the data definition, so I can't import data directly from WU to HWS.
From WU:
2018-7-24,27.9,22.4,16.9,22.3,19.2,15.6,97,83,70,1014,1013,11,0,18,0.00
From Jul.txt(mbcharts):
25 Jul,28.6,19.5,23.00,18.00,0.00,0.0,0.0,0.00,1015.80,1014.70,0
Data from WU must be changed before import to HWS. I thought others had the same challenge and had found a solution. There are 2 files pertaining to this, month.txt and year.txt
Rgds
gand
