Hello everyone.....
A problem has reoccurred just recently as this weekend and continues this evening and I'm getting a bit frustrated.
I have noticed that my outdoor temperature readings on my cabled Vantage Pro 1 are flucuating frequently. For example, the temperature was 13.3F and it suddenly jumped to 15.4F then went back to 13.3F and then to 14.2F and back to 13.3F... It would eventually return to normal for awhile...then do it again. It has occurred a lot since starting or when I noticed it....it happened several times around this time last year...it seems like only when it is very cold. I really have no explanation as to why this is occurring...I was wondering if anyone might have been in a similar situation or maybe has a solution??
I did check for splicing of cables and there was none....and most of cable is underground in conduit. I do have a rain gage heater and it was on during the issue (because it was snowing)...but I did shut it off to see what would happen and it still did it...
I also tried unplugging the cable from the console to my computer to see if it was a grounding issue (recommended by someone on another forum) and the fluctuations continued....
The temp/hum sensor is brand new as of last year...Davis thought it might be the sensor as I did contact them about the problem when it occurred before and had it replaced....also contacted them again today and got same freakin answer...replace sensor for $70...I don't believe that is the problem....
Thank you,
Chris
I sat at my computer with WeatherLink open and recorded the temps as the changed (about 3 minutes).....
12.6
13.8
12.8
13.3
12.8
13.6
13.1
12.8
13.3
12.8
13.8
12.8
