I haven't had one apart but the Davis wind vane appears to have some type of internal damping to help stabilize the direction readings. Even a brand new wind vane exhibits some resistance to rotation. Also, the large tail fin generates a lot of drag when you spin the wind vane by hand. If the vane turns smoothly you most likely don't have a problem. On the other hand, the anemometer cups should turn with the slightest touch.
