Author Topic: Getting Water inside ISS  (Read 2636 times)
Offline weathertwp
« on: March 09, 2008, 11:30:23 AM »
Some how or another I am getting water inside my ISS unit, then my base gets lines across the outside readings.
Well, when I bring the unit inside and let it dry out, it works great!!  Can't figure out how moisture is getting inside
the unit since it has the rubber seal around plate with the solar panel.
Any ideas ???
Thanks..
Offline ncpilot
    • Monkey Junction Weather
Re: Getting Water inside ISS
« Reply #1 on: March 09, 2008, 11:37:26 AM »
I recall reading somewhere that there might be a problem with the antenna seal...
Marc
Wilmington, NC
"Monkey Junction Weather"
Davis VP2 wireless, WeatherLink
Offline weathertwp
« Reply #2 on: March 09, 2008, 11:59:53 AM »
Well, that was what I thinking.. I just put some di-electric grease over the antenna
and it's seal. I hope that will work, this is the third time this has happened.
Offline capeweather
    • http://www.capeweather.com
« Reply #3 on: March 09, 2008, 01:09:27 PM »
Contact Davis about this. I believe they released a modification a year or so ago. Now I'm not exactly sure if it was for the antenna or the hole where the cables route through the housing but it's worth contacting them. Let us know what you find out.
Chris
Cape Coral, Florida
Offline Elderberry
  • Mike
    • SoHiWeather
« Reply #4 on: March 09, 2008, 03:02:42 PM »
The modification was for the antenna. I had the same problem and they sent me a sleeve to put over the antenna that solved the problem.
Offline weathertwp
« Reply #5 on: March 09, 2008, 04:03:47 PM »
Thanks..   I just sent them an email, hopefully the dielectric grease will work till
I hear from them.
