Author Topic: Meteotemplate - new free website template  (Read 631136 times)
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
Re: Meteotemplate - new free website template
« Reply #6275 on: March 20, 2017, 07:05:14 PM »
Thank you
Offline Jáchym
    • Meteotemplate
Meteotemplate - Plugin Update – Earthquakes 3.0
« Reply #6276 on: March 21, 2017, 08:00:55 AM »
Hi guys,
no-one actually noticed, but the plugin stopped working due to changed data source format. I fixed this so it is now working fine and in addition I added a new feature – possibility to export the map with the markers as a normal image file.
DEMO: http://www.meteotemplate.com/template/plugins/earthquakes/index.php
Enjoy
Offline nineback
    • Albertville, AL Weather
« Reply #6277 on: March 21, 2017, 09:06:54 AM »
When I originally set up my home page I set it for three blocks (25,50,25).  I now want to add one block (100%) that spans the entire screen.  How do I add a single block to my existing setup?
Tom
Davis VP+
Weather Display/WeeWX
http://www.kq5s.com/
Offline Jáchym
    • Meteotemplate
« Reply #6278 on: March 21, 2017, 09:15:39 AM »
Hi Tom,
this is what the header and footer blocks are for.
If you want it at the top, put its namespace to the Header block section, similarly if you want it at the bottom, use the Footer block
Offline nineback
« Reply #6279 on: March 21, 2017, 10:35:54 AM »
Too easy.
Tom
Davis VP+
Offline nineback
« Reply #6280 on: March 21, 2017, 10:49:06 AM »
I have the gauges showing at the top but the solar gauge is not showing anything and is indicating NaN in the middle.  Other places are showing the solar value just not the gauge.
Davis VP+
Offline nineback
« Reply #6281 on: March 21, 2017, 10:50:11 AM »
I should have mentioned I am using the API.
Davis VP+
Offline weatherbee
    • Sherman Ct. Weather
« Reply #6282 on: March 21, 2017, 11:20:42 AM »
Offline nineback
« Reply #6283 on: March 21, 2017, 11:45:53 AM »
Thanks Tom. I had to turn on the switch.  It is a little confusing as parts of the template are using the API and other I guess are still using the clientraw file.  Steel gauge were working fine and I saw the solar value on another screen as well.
Davis VP+
Offline weatherbee
« Reply #6284 on: March 21, 2017, 12:00:23 PM »
The different blocks and plugins could still be using clientraw.txt until you change them to the api.
Offline nineback
« Reply #6285 on: March 21, 2017, 12:07:45 PM »
I believe you are right.  I need to go through the settings and change them to API.
Davis VP+
Offline KapitainOne
    • Sanford Weather
« Reply #6286 on: March 21, 2017, 12:26:43 PM »
Jachym
Just tried to use the database backup selection in the admin panel for the first time on my new host but it never seems to complete!
Started it at 11:08 and it is now 11:25 and it seems to hang on creating the csv file for 2015, 2010-2014 completed with files sizes in the 9.2M range but 2015 seems to hang at 8.4M
Is there an error log somewhere that might hint what's happening??
Bill
Note, any login credentials you might have for me are no longer correct, if you need access pm me and I'll get them to you.
Offline nineback
« Reply #6287 on: March 21, 2017, 12:30:36 PM »
Anyone know how to turn off the all the 0, 1,2,3's etc inside the precipitation gauge.  I only want 1,2,3 to show the place on the graph that corresponds to 1,2,3 etc.  Now I get 10 ones, 10 twos, etc because I have the interval set to .1.  Funny I just noticed that I only have 5 0's showing.
Davis VP+
Offline Jáchym
    • Meteotemplate
Meteotemplate - Block Update – Thermometer 3.0
« Reply #6288 on: March 21, 2017, 12:37:44 PM »
Hi guys,
it is now possible to enable/disable display of today´s min/max.
DEMO: http://www.meteotemplate.com/template/indexBlockDemoNarrow.php?block=thermometer
Enjoy
Offline i_fiorentino
  • Davis Vantage Vue, Boltek Stormtr., Mobotix M22-IT
    • Meteopistoia.it
Re: Meteotemplate - Plugin Update – Earthquakes 3.0
« Reply #6289 on: March 21, 2017, 12:48:28 PM »
Hi guys,
Enjoy
Hi Jachym,
please check your download link, it seems broken.
Regards,
Alessandro
Offline Jáchym
    • Meteotemplate
« Reply #6290 on: March 21, 2017, 01:07:21 PM »
It is all down again, I was briefly at home and uploaded the file from my laptop and it again crashed. No downloads are working now.
Offline Juan Maria Vilaro
« Reply #6291 on: March 21, 2017, 01:21:24 PM »
Dear Jachym, I am Juan MŞ Vilaro, user of your template and request to download version 12.
http://www.meteobadalonaprogres.cat/template/indexDesktop.php
My email is: joanmariavs@telefonica.net
Thanks for your attention
« Last Edit: March 21, 2017, 01:24:34 PM by Juan Maria Vilaro »
Offline Jáchym
    • Meteotemplate
« Reply #6292 on: March 21, 2017, 01:51:05 PM »
ok it should be fine now
toke sent
Offline Jáchym
    • Meteotemplate
Meteotemplate - New Plugin – Czech Pollen Calendar
« Reply #6293 on: March 22, 2017, 12:38:52 PM »
Hi guys,
new plugin which shows a pollen calendar for Czech Republic.
DEMO: http://www.meteotemplate.com/template/plugins/pollenCZ/index.php
Enjoy
Offline nineback
« Reply #6294 on: March 22, 2017, 01:39:32 PM »
Anyone?
Davis VP+
Offline Jáchym
    • Meteotemplate
« Reply #6295 on: March 22, 2017, 01:47:17 PM »
Fixed:
http://www.kq5s.com/template/indexDesktop.php
You need to set the interval of major ticks to just 1 and 10 for the minor ticks. You set 10 for major ticks and 0 for minor.
Offline nineback
« Reply #6296 on: March 22, 2017, 02:03:58 PM »
Thanks.
Davis VP+
Offline Jáchym
    • Meteotemplate
Meteotemplate 13.0 Lemon
« Reply #6297 on: March 23, 2017, 08:46:14 AM »
Hi guys,
as mentioned in a previous post, this is a very minor update, I only needed to add some things to the index file, which will greatly increase potential for new blocks / block improvements. I have also fixed one minor bug in one of the pages.
I am primarily now working on version 14, which should be ready probably in a few weeks. I started working on version 12 in December, and I only wanted this to be about the api, which was problematic and required co-ordination and synchronization with other developers. I have started working on version 14 in January after your suggestions from the questionnaire. However I decided to release this one extra update with just the very few files because of the potential it will bring.
The update should take you maybe 10 seconds – only replace the index files, the footers and the one page from the pages/station directory, which has a minor bug in it (thanks Gus for letting me know).
I also disabled the token requirement, which means that this particular update (12->13) does NOT require a download token (others do as well as the whole template file).
V14 will be the next major update and I can already tell you that you really have something to look for and Im very excited about what I have already 🙂
Enjoy
Offline jeffm5690
    • Long Island New York Weather
« Reply #6298 on: March 23, 2017, 09:42:09 AM »
Hey there.  I started getting a strange error on my Bloomsky Timelapse Block.  The video is definitely there and the cron is running.  Any ideas?
Offline KapitainOne
    • Sanford Weather
« Reply #6299 on: March 23, 2017, 09:45:33 AM »
Love lemons!
Updated and all seems well!
