Author Topic: wxsim 3in1 script graph not showing  (Read 1132 times)
Offline Bashy
  • brecklandweather.com/meteo
    • Breckland Weather
« on: February 25, 2018, 02:25:18 AM »
Hi folks, any ideas as to why my graph i not showing please, i cannot think for the life of me as to what the issue may be?
http://brecklandweather.com/wxsim_wxall/sivu2.php
Kind regards
Bashy
Offline wvdkuil
  • Wim van der kuil
Re: wxsim 3in1 script graph not showing
« Reply #1 on: February 25, 2018, 03:25:46 AM »
The problem is discussed already in other topics at the WXSIM discussions on the weather-watch forum .
The overview tab / icons on top are generated from plaintext.txt => that file is always OK
The graph AND the two other tabs are populated by lastret.txt => http://brecklandweather.com/lastret.txt
As you can see NONE of the data lines are on the hour.
  TIME      WEATHER        AIR   DEW   WCF   HT.I  LVL1 W.DIR W.SP SKY  %RH  POP  PTOT THK       850T  TMAX  TMIN               SN.C  SLP  TSMO SWXO WDIR G10M         TSCD DATE/TIME
 3:56a CLEAR    LIGHT FOG  -1.8  -1.8  -6.7  -1.8  -1.2   49    9    0  100    0  0.0  5303      -0.9  -1.7  -1.9                0.0  1028 -2.9 -3.1  NE    13            0 2018-02-25_03:56_UTC
 4:26a CLEAR    LIGHT FOG  -1.7  -2.1  -6.8  -1.7  -1.4   49   11    0   97    0  0.0  5306      -1.4  -1.6  -1.7                0.0  1028 -4.1 -4.3  NE    15            0 2018-02-25_04:26_UTC
That script needs data lines which are exactly on the hour.
So adjusting the WXSIM settings to generate the data files at hh:00 will solve your problem.
Wim
« Last Edit: February 25, 2018, 03:29:12 AM by wvdkuil »
Offline Bashy
    • Breckland Weather
« Reply #2 on: February 25, 2018, 04:06:15 AM »
Hi, sadly i am am not allowed over there but thanks ever so much Wim, i have set them accordingly, i knew it would be something simple :)
Kind regards
Bashy
Offline wvdkuil
  • Wim van der kuil
« Reply #3 on: February 25, 2018, 08:06:42 AM »
As far as I know, all visitors are allowed to browse and search a forum.
Visitors are not allowed to post tickets if they are new to the forum.
Visitors are not allowed to to logon if they are banned.
Next time I will wait a day or two with an answer about a script from another developer, then you will not tell me " i knew it would be something simple"
Wim
Offline Bashy
    • Breckland Weather
« Reply #4 on: February 25, 2018, 08:25:51 AM »
It's based on ip as far as I am aware......
Wim
I think you may have misunderstood my comment, I had tried to figure it out and already spoken to Henkka, so posting was a last resort, fixes or work arounds are normally simple to resolve when  you know how, I just didn't have a clue, thank you again for the quick help.
Kind regards
Bashy
