Author Topic: Temp question  (Read 1394 times)
Offline chris1911
Temp question
« on: January 13, 2018, 04:02:51 PM »
Why does my WS-1200-IP not calculate the wind chill?  The "feels like" is always the same as the actual temp.
My dad has the same weather station and his does display the wind chill.
Offline waiukuweather
Re: Temp question
« Reply #1 on: January 13, 2018, 10:35:47 PM »
windchill only comes into use below 50F (10c) and of course the stronger the wind the low it is compared to the normal temperature
you do not say what your current conditions were at the time
Offline chris1911
Re: Temp question
« Reply #2 on: January 14, 2018, 10:18:49 AM »
I have had this weather station for almost two years and never seen the wind chill change from the actual temp under any conditions.
Offline unbidden
Re: Temp question
« Reply #3 on: January 15, 2018, 11:15:06 AM »
Same issue here. Didn't start happening until the recent firmware update. I haven't contacted Ambient yet but will possibly tonight/tomorrow.
Offline dupreezd
Re: Temp question
« Reply #4 on: January 15, 2018, 12:02:03 PM »
I have a 2 year old WS-1200-IP and my wind chill display correctly.
Display:-Software OS 5.4.4 Firmware 2.2.2
« Last Edit: January 15, 2018, 12:07:25 PM by dupreezd »
Davis VP2 6163 | WiFi Logger
CWOP - FW0717
Blitzortung 2100
Offline unbidden
Re: Temp question
« Reply #5 on: January 19, 2018, 02:13:43 PM »
Chris, I contacted Ambient and recieved this response:
Wind chill requires two things:
1. Temperature < 40 degF
2. Wind > 4 mph
<snip>
Ed
I monitored my machine via the ambient.net dashboard the the above criteria proved correct.
Offline chris1911
Re: Temp question
« Reply #6 on: January 21, 2018, 12:11:31 PM »
2. Wind > 4 mph
<snip>
Ed
Yeah, i had contacted them and that's what i was told.
Earlier in the week, we had some cold windy days.  I sat and watched my live data several times.  It would occasionally change the wind chill number briefly.  I think the problem is the location of my weather station.  My wind speed and direction is not as accurate as it should be.  I live in a subdivision with houses around.  They are spaced out pretty far, but i think it still affects my readings.  The fences everyone has probably creates some turbulence on the wind vane as well.  The only way to fix that is to mount it way up on the roof, which i am not going to do.
