Author Topic: Meteobridge won't send to weatherforyou  (Read 1268 times)
Offline captgadget
« on: October 12, 2017, 05:48:15 PM »
I have my WeatherLink IP connected to my router. In the communications port setting of WeatherLink it tells me the ip address. But when I go back to meteobridge I keep getting this error message:  error connect socket 192.168.1.6: port 22222: Operation now in progress
Offline Mattk
Re: Meteobridge won't send to weatherforyou
« Reply #1 on: October 12, 2017, 06:04:38 PM »
Running WLIP and MB (MB or MBPro) check the Select Station tab where you should have set the WLIP IP in the second box. In the first box are some drop down options which lets MB control the WeatherLink.com update rate so as not to create a conflict between 2 devices trying to read/access/upload the same data source together.
Offline captgadget
« Reply #2 on: October 12, 2017, 06:34:37 PM »
I have that set to no upload because I have WeatherLink handling that. I just want to sent weather to weatherforyou and I keep getting this error message. logger (12.10.2017 17:30:08): error connect socket 192.168.1.6: port 22222: Operation now in progress
logger (12.10.2017 17:34:08): message above repeats 8 times.
Offline Mattk
« Reply #3 on: October 12, 2017, 09:53:22 PM »
So is 192.168.1.6 the static IP of your logger? Did you change the WLIP address via the WLIP web page?
