Author Topic: Broke it. Acurite 5 in 1  (Read 1684 times)
« on: June 23, 2017, 11:04:51 AM »
the wire from the wind speed sensor to the main board.
Need a soldering iron.
now that both came off- Does it matter which wire goes where?
Offline DoctorKnow
Re: Broke it. Acurite 5 in 1
« Reply #1 on: June 23, 2017, 10:03:05 PM »
Nobody knows I guess....... Did you try it out yet?
« Reply #2 on: June 23, 2017, 10:07:53 PM »
No. Have to get to school and get my soldering iron.
Offline nincehelser
« Reply #3 on: June 23, 2017, 10:08:53 PM »
The wires go to a reed switch.  It shouldn't matter which goes where.
« Reply #4 on: July 08, 2017, 03:19:40 PM »
Took a while for me to get around to it. But I was able to fix it without an issue.
Should be fine as long as the stupid disrespectful kid that walks through everyone's yard leaves it alone.
Offline Inverno
« Reply #5 on: July 29, 2020, 09:12:02 AM »
I accidentally broke both my wind speed wires off too.  Was this an easy fix?  Did you have to take the whole board off to get to the back and solder?
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #6 on: July 29, 2020, 09:29:23 AM »
Solder his hands to his waist, that should fix it  =D>
Regards Simon
« Reply #7 on: July 29, 2020, 11:41:13 AM »
If you are somewhat experienced and handy, it should be an easy fix.
I have been lucky at home-no one messes with it.
Offline vreihen
  • El Niño chaser
  • K2BIG
« Reply #8 on: July 29, 2020, 12:33:34 PM »
