Author Topic: WD, Meteobridge & Davis Vantage Pro2  (Read 1902 times)
Offline lobsterman
    • Cape Small Harbor Weather
« on: September 13, 2016, 06:47:55 PM »
Noobie question here:
I have a meteobridge set up and sending data to my Saratoga templates, all in good order, though I am still working through the details.
To prevent unintended data loss, I am also having MB upload the Vantage Pro2 data to an SQL DB very 10 minutes.
When I fire up WD and connect it to the VP2, setting it not to use Meteobridge, I notice that the SQL table begins to have empty data uploads; when I quit WD, the data upload goes back to normal.
My question: does WD somehow clear the records from the VP2 logger? I am using the BelfreyBoy USB cable.
I note also that when I connect WeatherCat to the VP2 via IP, this apparent loss of data does not occur.
Am I missing a critical setting in WD, or something else here?
The work-in-progress site is http://suiattle.net/CapeSmallHarborWeather/mbridge/wxindex.php
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
Re: WD, Meteobridge & Davis Vantage Pro2
« Reply #1 on: September 13, 2016, 06:58:57 PM »
Sorry, I dont know the answer to your question, just wanted to say your good job on your site :-)
In case no-one here knows the answer I would also suggest asking on the official WD forum, Brian is extremely helpful and spends lot of time answering people's questions on the forum every day.
Offline hankster
    • NFM Weather
« Reply #2 on: September 13, 2016, 11:41:53 PM »
A popup will come up when WD downloads from the data logger. Make sure the delete data when done (or some such words) check box is not checked.
Offline lobsterman
« Reply #3 on: September 14, 2016, 10:14:25 AM »
On my MacOS El Capitan, WD version 10.37 build 271 I see no evidence of a popup, and the small window at bottom center of screen says WD is downloading data. Looked in the Data Logger control panel and saw no such checkbox. I'd be grateful for a pointer to where I can find it.
« Last Edit: September 14, 2016, 10:18:38 AM by lobsterman »
Offline Scalphunter
« Reply #4 on: September 14, 2016, 02:00:04 PM »
Control panel then data logger
Offline lobsterman
« Reply #5 on: September 16, 2016, 09:10:03 PM »
Well, found that and it's set to not delete data but all my historical data has now disappeared from both my WUnderground page and the Meteobridge --> Saratoga pages.
I'm obviously not grasping how the historical data is logged and saved by any of these systems.
