Author Topic: 2 Sensors on 1 Display  (Read 1085 times)
Offline PD_Weather
« on: May 30, 2014, 05:19:27 PM »
I just purchased a 1515 Weather station. It is working just fine. I have a 1015 Sensor that I would like to access off the same display. The newer 1515 is set to program A. Can I set the other sensor to program C and receive the information on Program C of the Display?
Offline nincehelser
Re: 2 Sensors on 1 Display
« Reply #1 on: June 05, 2014, 12:50:33 PM »
Theoretically, yes.
Practically,  you could get a confusing mess as the display tries to interpret the data over time.  Assuming you wait long enough to get a full set of data readings (give it about a minute) your temp, humidity, windspeed, wind direction should be correct.  However, anything that relies on readings over time (e.g. rainfall readings) is likely to be goofed up.
