Yes, ec-radar is next on my rework list based on Environment Canada changes today (16-Apr-2013)
I have completed the needed mods to ec-forecast.php (V2.14 - 16-Apr-2012)
Standalone users: get source or package from
http://saratoga-weather.org/scripts-ECforecast.php#ECforecastTemplate users: use
http://saratoga-weather.org/wxtemplates/updates.php for Base-Canada, 16-Apr-2013
Note: The EC has switched to using UTF-8 for their website so to retain the output as ISO-8859-1, a lot of iconv() calls
were added to the code. I found at least one instance of the EC posting text with mixed UTF-8 and ISO-8859-1 special characters which chokes the current PHP versions of iconv() .. so if you see a detailed forecast with funny characters in it,
that's the native UTF-8 showing as the iconv() failed .. hopefully, the EC folks will use UTF-8 throughout their forecasts so that issue should be few and far between.
Also, the URLs changed from weatheroffice.gc.ca to weather.gc.ca .. if you use $ECURLs with the old address, the code will replace 'weatheroffice' with 'weather' in the URL so it should work fine.
After loading up the new ec-forecast.php on your site, run the page with ?cache to refresh the cache file and your forecasts should display again.
I should have a fix for the ec-radar issue(s) tomorrow (17-Apr-2013)
Best regards,
Ken
