Thanks! I am thinking along the lines of a syntax error sort of problem. It takes a congressional act to get access to the server error log to see exactly which line is causing the trouble.
Thanks again!
The testscript returns a notice => not important
and a fatal error in line 39:
Fatal error:
Call to undefined function langtransstr() in /hermes/bosnacweb01/bosnacweb01am/b879/ipg.smythweathernet/wxquake.php on line 39
The script seems to need the Saratoga language translations functions.
Most scripts that start with
wx are designed to run in the Saratoga template.
So check if there is another starting script available. One for stand-alone use.
Wim
