Author Topic: wxflyer.php help  (Read 1939 times)
Offline cospringswx
    • Colorado Springs Weather
wxflyer.php help
« on: January 22, 2013, 05:45:17 PM »
I get the message below when I open wxflyer.php
Warning: fopen(./nws-forecast-discussion.txt) [function.fopen]: failed to open stream: Permission denied in /virtual/users/e17244-18991/web/wxflyer.php on line 413
Any ideas? I have permissions set to 666.
Line 413 is cache.
http://hayskansasweather.com/wxflyer.php
Ryan
Colorado Springs, CO
www.cospringsweather.com
Davis Vantage Vue
Weather Display Software
Amcrest HD IP Camera
Offline jmcmurry
  • Jim McMurry
    • Juneau County Weather
Re: wxflyer.php help
« Reply #1 on: January 22, 2013, 05:58:58 PM »
It's working now.
- Jim
Offline ALITTLEweird1
  • Mark
    • North Bend Weather
« Reply #2 on: January 22, 2013, 08:15:12 PM »
Its there again..
Not really recommended, but try changing your nws-forecast-discussion.txt file to 777 in the permissions just to see if that works.
Software: WeatherDisplay
Offline cospringswx
« Reply #3 on: January 22, 2013, 08:30:42 PM »
Sometimes it does it and sometimes it don't. Odd! Might leave it besides putting the permissions that high since its not recommend.
Ryan
Davis Vantage Vue
Offline cospringswx
« Reply #4 on: January 22, 2013, 09:40:59 PM »
I found the problem I think. I have no nws-forecast-discussion.txt file on my server!
Ryan
Davis Vantage Vue
« Reply #5 on: January 24, 2013, 04:28:37 AM »
It still gives that warning problem sometimes.  On my flyer at http://stillwaterweather.com/wx/wxflyer.php  a forecast discussion never shows up even with a nws-forecast-discussion.txt file in place.  I've noticed forecast discussion isn't showing up on some of the other sites with flyers as well.
Offline cospringswx
« Reply #6 on: January 24, 2013, 02:32:55 PM »
Yours looks great with no errors. Could I just tell the script not to look for one so I won't have an error?
Ryan
Davis Vantage Vue
« Reply #7 on: January 24, 2013, 03:36:08 PM »
Thanks.  Try putting two slashes at both ends of entry at around line 38 to look like this:
//$WRH_URL = 'http://forecast.weather.gov/product.php?site=NWS&issuedby=OUN&product=AFD&format=TXT&version=1&glossary=0';//
Offline cospringswx
« Reply #8 on: January 24, 2013, 03:48:52 PM »
I did that and I still get this...
When I first load the page it's fine but if you refresh the error comes back.
Ryan
Davis Vantage Vue
  • Mark
« Reply #9 on: January 24, 2013, 08:34:03 PM »
Are you sure you have the .txt file on your site? I cant see it here.. http://hayskansasweather.com/nws-forecast-discussion.txt
Here's what mine looks like... http://www.northbendweather.com/nws-forecast-discussion.txt
Offline cospringswx
« Reply #10 on: January 24, 2013, 09:00:53 PM »
That's what I said. I don't.
Ryan
Davis Vantage Vue
Offline Dr Obbins
« Reply #11 on: January 24, 2013, 09:24:07 PM »
Using notepad create a blank file and when saving the file, name it
Then upload it to your site and change the file permissions to 666.
« Reply #12 on: January 24, 2013, 10:23:19 PM »
Sorry, but the forecast discussion isn't working on your flyer, either.  As I stated before other people have this problem.
« Reply #13 on: January 24, 2013, 10:25:17 PM »
Congratulations, the forecast discussion part of your flyer works!
Offline Dr Obbins
« Reply #14 on: January 25, 2013, 01:35:53 AM »
Yes - I Know. My flyer is modified and does not include the forecast discussion on purpose so the flyer does not get too long and stays on one page. ;)  The line
<?php
// make a short paragraph of the forecast discussion
$Status $curl_debug '';
echo
get_forecast_discussion_flyer();
has been deleted and instead there are 2 more forecasts. The nws-forecast-discussion.txt from 2010 still exists because it is not in use.
I have found that sometimes the scripts don't create the needed txt files the first time, but when one is manually created, the script starts working and overwriting on it. This may or may not work for you, but it doesn't hurt to try. I see that you also have your files in a subfolder of your main directly /wx/. Have you checked for a path issue?
« Last Edit: January 25, 2013, 01:37:37 AM by Dr Obbins »
