Author Topic: saratoga template - issues with date format  (Read 516 times)
Offline jmwarren21
    • myweatherstations.com
« on: February 18, 2017, 11:33:01 AM »
I am setting up a website using the saratoga-weather template.  I am having trouble getting the date formatted correctly.  I have searched the forum, but so far, I have been unable to fix the issue.
My site is at http://myweatherstations.com/
The date shows 18/2/2017, I want it to be Feb 18, 2017.  I am using WD and the latest version of the saratoga template.  Any assistance you could provide would be appreciated.
Jason
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
Re: saratoga template - issues with date format
« Reply #1 on: February 18, 2017, 12:03:11 PM »
What date/time format did you specify in the Settings.php?
Offline jmwarren21
« Reply #2 on: February 18, 2017, 12:21:55 PM »
Here is the code from my settings.php file...
$SITE['timeFormat'] = 'D, d-M-Y g:ia T';  // Day, 31-Mar-2006 6:35pm Tz  (USA Style)
//$SITE['timeFormat'] = 'm/d/Y g:ia';      // USA  format 03/31/2006 14:03
//$SITE['timeFormat'] = 'd/m/Y H:i';       // Euro format 31/03/2006 14:03
//$SITE['timeFormat'] = 'Y-m-d H:i';       // ISO  format 2006-03-31 14:03
$SITE['timeOnlyFormat'] = 'g:ia';          // USA format h:mm[am|pm\
//$SITE['timeOnlyFormat'] = 'H:i';          // Euro format hh:mm  (hh=00..23);
$SITE['dateOnlyFormat'] = 'd-M-Y';        // for 31-Mar-2008 or 'j/n/Y' for Euro format
$SITE['WDdateMDY'] = false; // for WD date format of month/day/year.  =false for day/month/year
Offline Jáchym
    • Meteotemplate
« Reply #3 on: February 18, 2017, 12:37:02 PM »
Looking at your HTML, the format for date you have specified in the setting is
and this is indeed in the HTML of the page, however as soon as the page updates for the first time it changes to d/m/Y
I checked the JS and it looks like it is taking the date format directly from your clientraw.txt, which has d/m/Y
See if this can be changed in WD or Im afraid we will have to wait for the expert (Ken) :-) Sorry, I dont use Saratoga myself.
« Reply #4 on: February 18, 2017, 12:47:04 PM »
There are two paths to have the date/time set.  The first is the PHP page and the Settings.php control the format of the date/time.
When the AJAX script (ajaxWDwx.js for Weather-Display) starts executing, it takes the date/time from clientraw.txt and does not reformat it.. just displays the 'raw' data based on your Weather-Display settings.  In WD, Control Panel, Units&OtherSettings, Precision/Time/Date/Cloud Height TAB you only have two choices for the WebPage/WebCam date format:  month/day/year or day/month/year.  Change that to month/day/year and it will show the USA format for the date.
I suggest you also change Settings.php date/time specs to use month/day/year instead of day-Mon-year format so they will match what WD will display throughout the rest of the site.
Offline jmwarren21
« Reply #5 on: February 18, 2017, 12:52:51 PM »
That did it.  Thank you both so much for your help!
« Reply #6 on: February 18, 2017, 12:57:56 PM »
Don't forget to change Settings.php
to
$SITE['WDdateMDY'] = true; // for WD date format of month/day/year.  =false for day/month/year
now that you've switched WD to use month/day/year format for the webpages.
