Author Topic: WU delivers incomplete yearly CSV data  (Read 5653 times)
Offline PaulMy
Re: WU delivers incomplete yearly CSV data
« Reply #50 on: December 14, 2016, 10:25:53 PM »
The PWS historical data will be restored, but it's likely a few weeks out. We're short-staffed at the moment and have a lot of items on the to-do list.
But I understand if you choose to send your data elsewhere.
(directly telling you to send data elsewhere...)
I assume presume the enquirer suggested that that he could send his data elsewhere, and William acknowledged that is an option, not suggesting to change.
We are a discriminating group ;)
Enjoy,
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
« Reply #51 on: December 15, 2016, 06:39:45 AM »
Well it could also be that he simply understands their site is becoming unusable... I mean just now there are 3 parallel threads discussing parts of WU not working.... if it really is such a problem to get at least the fundamental pages working, then they either don´t care and don´t give the time to it, or these people are unable to do it no matter how hard they try - my opinion.
Offline WessexWeather
    • WessexWeather
« Reply #52 on: December 15, 2016, 08:06:36 AM »
Yes, I would like to start sending my data elsewhere, so that I can present it on my website. I currently use some excellent scripts that utilise historical data from WU but this can no longer be relied upon.
I use Meteobridge and will soon start saving my data into a MySQL database. Once there, how can I easily query this database for presentation on my website?
Thanks in advance for any suggestions.
Cheers,
Simon (WessexWeather)
Offline Jáchym
    • Meteotemplate
« Reply #53 on: December 15, 2016, 08:09:20 AM »
you then need to create PHP scripts that will first retrieve the data and then some other code that will display it, ideally using also graphs etc. That´s exactly what my template does, I created it for that very reason - I did not want to rely on WU and I also have scripts built-in the template that will import history data from WU so that one does not have to start from scratch.
You will need PHP, some charting library, Javascript etc. depends how familiar you are with these.
    • WessexWeather
« Reply #54 on: December 15, 2016, 08:13:56 AM »
Thanks for the reply. I'm not at all familiar with php which is why I have taken the WU route. I will have to look into this further over the Christmas holidays.
Cheers,
Offline Jáchym
    • Meteotemplate
« Reply #55 on: December 15, 2016, 08:23:31 AM »
In case you are interested have a look at my template, it is all set via GUI, no need to know coding whatsoever and if you want Im happy to help you with it, I just installed it to one guy this weekend and I do that on a daily/weekly basis.
    • WessexWeather
« Reply #56 on: December 15, 2016, 08:44:23 AM »
Jáchym,
That looks very good - you have obviously put a lot of work into this. And all this can run from a Meteobridge uploading to a MySQL database?
Cheers,
Offline Jáchym
    • Meteotemplate
« Reply #57 on: December 15, 2016, 09:07:24 AM »
Yes, in fact that is exactly my setup and using MB is by far the easiest because you don´t need to worry about any CRON jobs, all that is built into MB
Offline Jáchym
    • Meteotemplate
« Reply #58 on: December 15, 2016, 09:08:12 AM »
I can pretty much set you up within an hour including everything and it can run from a subfolder so of course you don´t need to do anything with your current website, it will all stay as it is now, only alternative
    • WessexWeather
« Reply #59 on: December 15, 2016, 09:24:00 AM »
It all looks very impressive and I will certainly look into it over the Christmas period. Thank you.
Cheers,
Offline Jáchym
    • Meteotemplate
« Reply #60 on: December 15, 2016, 09:34:01 AM »
Email me if you need help, I can help you via email or Skype.
Offline Mtn_man
    • Sunset Mountain Weather
« Reply #61 on: January 05, 2017, 11:07:52 PM »
For the time being it looks like WU has resolved the issue with missing historical data.... mostly.  All of the 2016 data is now accessible, except the last 3 days of the year, which are missing.
« Last Edit: January 05, 2017, 11:10:18 PM by Mtn_man »
    • WessexWeather
« Reply #62 on: January 06, 2017, 01:26:00 AM »
I'm still only getting the last 3 months of 2016!
http://www.wessexweather.net/observations.htm
Cheers,
Offline jmcmurry
  • Jim McMurry
    • Juneau County Weather
« Reply #63 on: January 06, 2017, 05:53:32 AM »
Try removing/renaming the "year-2016" file in the cache, then the script will create it new.  I did this just yesterday.
- Jim
Offline jgillett
  • unnamed weather station, Boltek, Win7 Pro, ToA
    • TiggrWeather Phoenix
« Reply #64 on: January 06, 2017, 11:59:59 AM »
I don't get anything (except as attached). Removed the cache file and also tried the ?forceupdate=1. Still the same essentially blank page. No idea when this started as I haven't looked at this page in a long time.
Thanks.
W7JKG
BUY FROM AMAZON  HERE... Thank You! :-)
