Note: this was moved from the Davis Instruments forum and replies quoted below>
Yesterday, 10.6.16, MBPro stopped uploading both to WU and to my webpage (alriksyweather.net). I rebooted and things were working until this morning when the webpage stopped updating. Rebooted again but I noticed that WU was updating at irregular intervals , 2min, 1min, 5min, 1min, 10min, etc.. The live data tab shows updates occurring with past time. For example, MB updates at 14:05 when the real time is 14:34. Updates are occurring at random times on the web page, with large gaps. The time setting in MB is correct, Lat and Long. correct, and the time zone is correct. I decided to try a direct ethernet connection.
Now, everything is updating on a regular schedule. WU is at 5min, WU rapid-fire about 5 sec, meteotemplate page live gauges at about 5 sec. I do not have a weak wifi signal -58db but for some reason this appears to have been a problem? I even tried a different wifi router but still did not get regular updates. I'm not a network expert, but wonder if inconsistent communication with the router via wifi caused a packet issue and extreme delays or whether MB is having wifi issues or uploading problems.
After an hour or so of regular updates, the meteotemplate page is not updating regularly but WU is. The server db is now lagging 45min behind the live gauges, but they are slow too. Maybe it isn't an ethernet solution after all. I am new to the forum and MBPro so I am sure someone understands this better than I do and knows what to try now.
Jachym posted the following reply:
Boris:
just to add to it, Boris, we also checked the Live tab in the MB cPanel and the times of HTTP uploads are incorrect/old there too, so this must be an issue with MB, not the template. For some reason it seems to be uploading absolutely randomly and with incorrect timestamp.
Eg: we looked at 14:20, last time of update was 13:50 (updates set to every 5 minutes)
Then, we looked at 14:40 and last update time was now 14:05, so MB must have updated between 14:20 and 14:40 when we checked it, but sometime between that time it updated with a time 14:05.
Then it doesnt do anything for hours, then suddenly it starts updating again, sometimes both Meteotemplate and WU are affected, sometimes only one.
Also, it has been running for several days fine until yesterday, with the same time and wifi settings, nothing changed.
