Author Topic: YAWCAM (or WD LIVE Streaming video) on my site???  (Read 11474 times)
Offline Chris_K
    • Bucks County Weather
« on: December 22, 2010, 12:45:53 PM »
Not sure where to get started, but currently I use the Carterlake template set for my site.....I'd like to embedd a live stream using YAWCAM program into a site page, but I have no idea how to do it. I tried using WMP embedded but errors show up saying I'm broadcast the wrong file type?
Chris
Offline Stetson1
  • Cordera Weather
    • Cordera Weather
Re: YAWCAM (or WD LIVE Streaming video) on my site???
« Reply #1 on: December 22, 2010, 12:59:16 PM »
Well I would certainly be interested in the solution. I am using Yawcam now and have attempted the streaming in the past with little luck.
Todd
Offline mmorris
  • Hope your day is full of sunshine
    • Weather and Racin
« Reply #2 on: December 22, 2010, 01:27:56 PM »
Well if you want to stream from the computer that has Yawcam on it you need to get a Domain name for your computer I got mine from DynDNS.org
then you have to choose a stream port in Yawcam I have mine set to 8081
If you have a router you need to open that port to the web
course you have to turn on streaming in Yawcam
 to view you just need to put http://your domain name:8081
in your browser and it should open up your Yawcam in the browser.
Course you might want to setup password under password in Yawcam
I'm using an older ver of Yawcam as I found it easier to setup more then one camera.
Follow me on twitter
Quadruple Bypass survivor
Offline Chris_K
« Reply #3 on: December 22, 2010, 01:29:45 PM »
I've reached the part where I can see , from another computer via the net, a live picture, but I would like to use Windows Media Player to broadcast for viewing. YAWCAM streams using Java, and no matter how I set WMP its not correct.
Chris
Offline mmorris
    • Weather and Racin
« Reply #4 on: December 22, 2010, 01:40:52 PM »
Well guess your got to fine a windows media player person. Just hate it when you have an Idea that there just is not the right software to put it together.
Offline CNYWeather
    • CNYWeather
« Reply #5 on: December 22, 2010, 04:36:41 PM »
You using the ajax or html version??
If Ajax, try this and insert your IP address and port number
<?php
# A Project of TNET Services, Inc. and Saratoga-Weather.org (WD-USA template set)
#   Project:    Sample Included Website Design
#   Module:     sample.php
#   Purpose:    Sample Page
#   Authors:    Kevin W. Reed <kreed@tnet.com>
#               TNET Services, Inc.
Copyright: (c) 1992-2007 Copyright TNET Services, Inc.
# This program is free software; you can redistribute it and/or
# modify it under the terms of the GNU General Public License
# as published by the Free Software Foundation; either version 2
# of the License, or (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA  02111-1307, USA
# This document uses Tab 4 Settings
require_once("Settings.php");
require_once(
"common.php");
$TITLE$SITE['organ'] . " - LIVE Weather Cam Page";
$showGizmo true;  // set to false to exclude the gizmo
include("top.php");
</head>
<body>
<?php
include("header.php");
include("menubar.php");
<div id="main-copy">
<h3>Webcam Image</h3>
<br>
<br>
<table id="table1" width="80%" border="1">
<tr>
<td width="414" class="style2">
<span class="style3"><strong><br>
Live Stream of the front webcam<br>
</strong><span class="style1">Looking North Towards
Downtown Rome, NY (approx 3 miles away)</span><br>
<br>
Cam Location: Corner of West Carter Rd. and Lower Lawrence Street Westmoreland, New York<br>
<br/>
<OBJECT ID="MediaPlayer1" width=640 height=480
   classid="CLSID:22D6F312-B0F6-11D0-94AB-0080C74C7E95"
   codebase=
   "http://activex.microsoft.com/activex/controls/mplayer/en/nsmp2inf.cab#Version=5,1,52,701"
        standby="Loading Microsoft® Windows® Media Player components..."
        type="application/x-oleobject">
  <PARAM NAME="FileName" VALUE="http://your.ip.address.here:portnumbertoo"
  <PARAM NAME="ShowStatusBar" VALUE="True">
  <PARAM NAME="ShowPositionControls" VALUE="False">
  <PARAM NAME="ShowTracker" VALUE="False">
  <PARAM name="ShowControls" VALUE="True">
  <PARAM name="Volume" VALUE="1" />
  <PARAM name="Mute" VALUE="True"/>
  <EMBED type="application/x-mplayer2"
   pluginspage = "http://www.microsoft.com/Windows/MediaPlayer/"
   src="http://your.ip.address.here:portnumbertoo"
   name="MediaPlayer1"
   width="640"
   height="480"
   ShowStatusBar="True"
   ShowPositionControls="False" ShowTracker="False" ShowControls="False">
  </EMBED>
</OBJECT>
<br>
</strong>
</span>
<br>
<br>
</td>
</tr>
</table>
<p>
<img style="border-width: 0px;" alt="picture: logitech quickcam for notebooks pro" src="http://www.cnyweather.com/images/logitech.png" width="175" height="87"><br>
<br>
This weather cam is a Logitech Quickcam for Notebooks Pro 9000<br>
using Weather Display WebCam Capture Software</p>
</p>
</div><!-- end main-copy -->
<?php
include("footer.php");
# End of Page
Tony
Offline Chris_K
« Reply #6 on: December 22, 2010, 05:03:19 PM »
Thank you....www.bucksweather.com/wx2cam.php
Open the viewer but no matter what I put in for the IP, whether from WD or YAWCAM its blank...
If a person just puts in the address "http://173.49.55.42:8081" all works fine........just not in the carterlake set...
Chris
Offline CNYWeather
    • CNYWeather
« Reply #7 on: December 22, 2010, 07:50:04 PM »
Change your IP values in the script
from http://173:49:55:42:8888
to
http://173.49.55.42:8888
dots not colons in your IP address, then the colon for the port #
Tony
Offline Chris_K
« Reply #8 on: December 23, 2010, 04:40:35 AM »
Won't show a pic when using YAWCAM....when using WD it will stream nicely thru my LAN only.......I'm working this morning but will work on it when I get home later..
Thanks again.
Chris
Offline CNYWeather
    • CNYWeather
« Reply #9 on: December 23, 2010, 06:57:28 AM »
I see it's connecting but thats as far as it gets.
Do you have a router and did you open up port 8081 for the livestream?
Tony
Offline Chris_K
« Reply #10 on: December 23, 2010, 10:24:06 AM »
I do have a router and port 8081 is open...I will double check..
Chris
Offline Chris_K
« Reply #11 on: December 23, 2010, 10:29:47 AM »
port 8081 is open both tcp and udp......between starting my Christmas shopping and finishing it this afternoon I'll check back...
thanks..
Chris
