Weather Station Hardware > Weather Radios
Midland WR-300 NWS Radio Not Working?
Red-Dave:
Hey all.
You weather geeks might get a kick out of knowing that I picked up a WR-300 at a local used computer shop today for the whopping grand total of $8!!
Everything went fine through the setup process until I tried to listen to my local NWS broadcast. My local frequency is 162.55 so that's channel 7 according to the manual. Not a sound. It's not likely to be a reception problem as I can see the beacon from the top of what I think is the transmitter site right through my window, about 2 miles away.
Can someone think of a setting in there which might cause the WX radio to be muted? The AM/FM part works fine.
Please tell me my precious $8 wasn't wasted!! :grin:
Thanks!!
lddaly:
I purchased a new WR-300 in 2009. It worked for a short while, then the weather side stopped working just like yours (AM/FM was fine.) Because it was new, I contacted Midland and they replaced it. The replacement WR-300 is still functional today and is streaming KEC56 at http://www.planoweather.com/wxradio.php.
I seem to recall this being a common problem with a batch of WR-300's around that time period. Maybe someone else can confirm.
UPDATE: I found this old thread: http://www.wxforum.net/index.php?topic=8474 Mine wasn't silent, it made a high pitched squeal on all weather channels. Maybe yours is a different issue.
Red-Dave:
So, when the radio stopped working for you, did the WX alert function still work? I could stand missing the radio as long as it still displayed and processed alerts properly.
lddaly:
I do not recall #-o, but according to my post from 9 years ago, it did not alert.
--- Quote from: lddaly on August 19, 2010, 11:04:53 PM ---I checked my WR-300 yesterday when it did not alert for a thunderstorm warning and it is doing the EXACT same thing... high pitched squeal on the weather channels. It sounds like a feedback loop. #-o Mine is about the same age as yours.
--- End quote ---
rdsman:
--- Quote ---So, when the radio stopped working for you, did the WX alert function still work?
--- End quote ---
If you can't hear audio, it will not process alerts. Have you tried any other frequencies? Maybe the station you are trying to receive is off the air......
[#] Next page
